Oil pressure gauge sensor leak
jberd45
- Year and Trim: 1996 SE
My oil pressure gauge sensor leaks no matter what I do. I tightened it up, put on teflon tape and re-installed it; but no matter what it leaks a lot after a day or two. What can I do to fix this?
- MattStrike
- Year and Trim: '99 Montana
'04 Dirtymax
'97 Camaro
Re: Oil pressure gauge sensor leak
Are you sure it's leaking out the threads? Take the connector off and see if it's leaking out the end first. I usually use a paste applied thread sealant, there are some marketed toward the automotive that your local parts store should have on hand. I usually have problems with the teflon tape on anything but cast iron pipe.
Boost addict
The Fleet:
'97 Camaro - Top swap
'05 STS - V8, AWD, her DD
'92 Trofeo - Fair weather DD
'99 Montana - top swap 3800
Current project:
Something cool, trust me.
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
Gone to greener pastures:
'97 LeSabre - Top swap
RIP:
'86 LeSabre - pictures
'93 SE - L67
The Fleet:
Current project:
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
RIP:
'93 SE - L67
- J Wikoff
- Year and Trim: 1992 SSE
I used teflon tape on mine, I believe. No leaks. Or do they come with sealer on them... it's been a while.
2003 SSEi
- Year and Trim: 2003 SSEi.
LOTS of Mods
New Senders come with a Red Sealant on them
jberd45
What if it is leaking out the end? Would I need a new sender?
- MattStrike
'04 Dirtymax
'97 Camaro
If it leaks out the end then yes you would need a new sender.
Boost addict
The Fleet:
Current project:
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
RIP:
'93 SE - L67
The Fleet:
Current project:
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
RIP:
'93 SE - L67
- 92BonneSE
- Year and Trim: 2008 Aura XE
Yeah you need to get a new one. They don't cost much though and aren't too hard to replace
2017 Cruze RS
2008 Aura - Totaled
Sold but never forgotten:
1998 Bonneville SE
1992 Bonneville SE
