Engine Mount Question With Pic!
BonnevilleSE2000
Year and Trim: 2000 SE
Post by BonnevilleSE2000 »
Image I recently saw this video of a broken engine mount. http://www.youtube.com/watch?v=oGCIkHEqXuY The year of the Park Avenue is 2000 and so is my Bonneville... So I am concerned of the condition of my engine mount. What are your thoughts? How can I tell if it's broken? Thanks for the help! I hope the links work.
redzmonte
Year and Trim: 2000 SSEI
Re: Engine Mount Question With Pic!
Post by redzmonte »
if its original then its most likely bad. with the hood open, have someone in the car put the trans in Reverse and with the brake held down firmly give it a little gas, you will see the engine move alot and the mount will show seporation. search on the board for puck mount if you want to make a cheap better option to a original replacement, i also posted another bolt in option (with a couple spacers) that is a Vette motor mount if you want to try it i think that will be my next tinkering on mine.
they are not to hart to replace btw.
Shane "RedZMonte"
2004 Z16 Z06: Virgin
BonnevilleSE2000
Good call! I don't have an extra set of eyes around here so I filmed it instead! http://s1325.photobucket.com/albums/u63 ... eMount.mp4
redzmonte
Post by redzmonte »
Nice, seems like it has a bit of excess movment. once the mount is out youwill see the middle is most likely all blown out. looks like there is some craking around the top in the pic. again if its original then its prob bad.
Shane "RedZMonte"
BonnevilleSE2000
Yeah I can't wait to replace it. I would like to do the puck mod since I already have pucks. What diameter of threaded steel rod should I get? I'm assuming I would use some tension washers as well...
I prefer a 1/2" by 8" bolt. One less nut to worry about loosening up...
MattStrike
Year and Trim: '99 Montana
'04 Dirtymax
'97 Camaro
'92 Trofeo
Post by MattStrike »
Do you like vibration or like it smooth?
Solid would be pucks sandwitched between the subframe and mount, with a bolt and nut. Anytime you have torque to the wheel's it's in tension with no give. Works good for launching, but engine vibrations translate directly to the subframe and through the steering wheel.
Nut
mount
pucks
subframe
bolt head.
If you don't like vibration you need to put a bushing on top and/or bottom, more bushing = less vibration so you could tune it for a 'best of both worlds', between the bolt head and sub-frame or between the nut and the mount. This will have a little give during launch, but overall is going to be much smoother.
nut
washer
bushing(s) (such as rubber or PU sway bar end links drilled out to match the bolt)
mount
pucks
subframe
bushing(s)
washer
bolt head
Boost addict
The Fleet:
'97 Camaro - Top swap
'05 STS - V8, AWD, her DD
'92 Trofeo - Fair weather DD
'99 Montana - top swap 3800
Current project:
Something cool, trust me.
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
Gone to greener pastures:
'97 LeSabre - Top swap
RIP:
'86 LeSabre - pictures
'93 SE - L67
BonnevilleSE2000
I wouldn't mind extra vibrations. A solid puck mount would be fine for me. :beerchug:
You do want the bushings under the head of the bolt. I get no vibrations, but all the benefits of the solid mount. You probably need to replace your sway bar endlinks anyways, so just take one of the old bushings from that.
BonnevilleSE2000
Image Good idea! But I had my sway links replaced last summer and don't have the old parts. I actually settled with a stock replacement engine mount since I don't have access to essential tools for installing the puck mod. I'm going off to college next year and for now I want to make sure my Bonneville is in good shape. But when I graduate and have my own place with tools... I will enjoy tinkering :)
93 SSE 4 ME
Post by 93 SSE 4 ME »
I just replaced my mount earlier this week. $40 + tax for the mount. Can't see going thru the PITA the hockey pucks entail for $40. The bottom bolt spun free because the mount was so bad. If that wasn't the case it's a 30-45 minute job.
Mark
'05 Bonneville SLE Intense FWI & PCM, Wood Dash Kit, Chrome Valve Stem Caps!
'14 Silverado LTZ
'08 Acura TL
'05 VW Passat GLS
Most of the aftermarket mounts seem to last about a month...
Like I said, my mount has no vibrations, and probably took another half hour to drill and install.
deano55
Year and Trim: 2003 Bonneville SSEI
Post by deano55 »
00Beast wrote:Most of the aftermarket mounts seem to last about a month...
wow only a month? they must be made in china
drift7one
Year and Trim: 2002 Pontiac Bonneville SE
Post by drift7one »
my '02 SE is on its 3rd front mount in a little less than the 7k miles Ive had it.
I plan in hitting the local hockey pro shop and hardware store this spring to make the puck mount.
drift7one
Rich- Member #6668
Golden Hurricane
| Cleared Headlights | 20% Tinted Windows | AVS VentVisors | Viper 2-Way Alarm System | Garmin GPS Navigation |
| DDM Tuning 8000k 35w HID Headlights | Nokya Hyper Yellow 2500K Fog Lights | Black PlastiDip Accents & Badges |
flatlander745
Post by flatlander745 »
BonnevilleSE2000
I replaced the old engine mount and here it is: [img][IMG]http://i1325.photobucket.com/albums/u638/Eric_Bargaehr/th_OldEngineMount.jpg[/img][/img]
You used the wrong set of tags for a video:
BonnevilleSE2000
Oops #-o what's the right way then? Is it the URL?
