Is this Rim Fixable ? Chrome-Aluminium Oxidation Bead Leak ?
SPLLOUDER
Year and Trim: 2001 BONNEVILLE SLE
Post by SPLLOUDER »
I Took a 2000 Swoopie Rim to the tire shop today to get it Dunk tested to see why this newer tire is still going flat .
it has a bad inner bead leak , so they took the tire off and this is what we seen ?
Is it fixable at all or it a goner ?
2001 BONNEVILLE SLE (Galaxy Silver)
2002 BONNEVILLE SE (Galaxy Silver) (DD)
crash93ssei
Re: Is this Rim Fixable ? Chrome-Aluminium Oxidation Bead Le
Post by crash93ssei »
That looks like a chunk is missing from the bead? That is some horrible corrosion! If there is a chunk missing it will require welding to fill it back in from a wheel repair shop. It is definitely repairable, just depends on if it is cheaper to repair or get a other wheel. I would bet though it is cheaper to get another wheel.
ga93sle
Year and Trim: 06 Grand Prix LS4
Post by ga93sle »
Yeah, it can probably be fixed, but it's probably cheaper to buy a different rim...
*Chris*
15 Nissan Altima 2.5SL/2004 Honda Shadow 750 Aero
Previous, 07 GP SE, 06 GP GXP, 97 SSE 40th, 96 LeSabre Custom, 93 SLE, 90 LeSabre Custom
RogueSSEi
Year and Trim: 98 Pontiac Bonneville SSEi
Post by RogueSSEi »
Yes it's repairable. I ordered some GP wheels that had that oxidized crud on it, been sandblasting them and they are turning out to look ok.
yonkerse
Post by yonkerse »
I had some with similar oxidation and mine were cleaned up with new tires installed. Been 20k miles and no leaks to this point.
Eric
2005 SLE, Greystone Metallic, 152K.
A few mods..
01bonneSC
Year and Trim: 05 Chevy 'Hoe
89 SkiDoo
Post by 01bonneSC »
Drill with a wire cup works great.
Wire wheel it and then make sure the shop that mounts it uses a good amount of bead sealer.
SPLLOUDER
Post by SPLLOUDER »
Thanks for all the help !
Yes its Corrosion like the chrome started to bubble up badd and then water got in there and started making a aluminized corrosion impressions .
Ok so like a wire wheel on a corded drill . than maybe some buffing and make sure they use alot bead sealer .
i will be doing this sunday . i will keep everyone updated .
RogueSSEi
Post by RogueSSEi »
SPLLOUDER wrote: Ok so like a wire wheel on a corded drill . than maybe some buffing and make sure they use alot bead sealer .
Yes that'll work. Use PPE of course.
SPLLOUDER
Post by SPLLOUDER »
yes i definitely plan on wearing my safety glass's and i have some mechanic gloves for sure :beerchug:
vogie01
Post by vogie01 »
I had a rim that looked similar. Had the inside of it refinished and painted with a flat paint after it was cleaned up and I have not had any issues. It was sandblasted and painted.
When I worked at a tire shop, we had a grinder with a wire wheel mounted right to the tire machine, and you spun the rim as you cleaned up the bead with the wire wheel. Cleaned wheels up perfectly.
SPLLOUDER
Post by SPLLOUDER »
I Used the Crimped Wire Cup . Worked Great . But there is is some bad Pitting and scartch marks from me grinding .
Think it will hold up now ? i need to take some pics too ....
01bonneSC
89 SkiDoo
Post by 01bonneSC »
Gob on bead sealer, you will be fine.
SPLLOUDER
Post by SPLLOUDER »
Ok i cleaned it up and took it back to the tire dude . and he said he don't use Bead Sealer .
I dropped it off and he remounted and said it still leaks but not nearly as bad .
Guess i have to find a tire dude that like bead sealer LOL
RogueSSEi
Post by RogueSSEi »
In your proof on the car, does air leak?
SPLLOUDER
Post by SPLLOUDER »
RogueSSEi wrote:In your proof on the car, does air leak?
Have not mounted it yet to car and see . will do soon :beerchug:
