SPLLOUDER
Posts: 398 Joined: Sat Jul 07, 2012 5:01 pm
Year and Trim: 2001 BONNEVILLE SLE
Post
by SPLLOUDER » Sat Oct 13, 2012 5:14 pm
I Took a 2000 Swoopie Rim to the tire shop today to get it Dunk tested to see why this newer tire is still going flat .
it has a bad inner bead leak , so they took the tire off and this is what we seen ?
Is it fixable at all or it a goner ?
2001 BONNEVILLE SLE (Galaxy Silver)
2002 BONNEVILLE SE (Galaxy Silver) (DD)
crash93ssei
Posts: 7671 Joined: Mon May 19, 2008 6:08 pm
Post
by crash93ssei » Sat Oct 13, 2012 5:18 pm
That looks like a chunk is missing from the bead? That is some horrible corrosion! If there is a chunk missing it will require welding to fill it back in from a wheel repair shop. It is definitely repairable, just depends on if it is cheaper to repair or get a other wheel. I would bet though it is cheaper to get another wheel.
2003 Bonneville SSEi - The Black Mirror
SOLD!
2002 Bonneville SE -
The Mutt Complete 2004 SLE interior, drivetrain, and body harness swap, ECC swap, HUD swap, black GXP wheels, GXP headlights and tinted tails - SOLD
2003 BMW 540i M Sport ,
2001 BMW X5 4.4i ,
2010 GMC Acadia ,
2017 Grand Design Imagine 3150BH
MattStrike wrote: It was the worst week of my life! *pause, drinks beer... smiles* But I'm better now!
ga93sle
Posts: 3967 Joined: Wed May 21, 2008 11:14 pm
Year and Trim: 06 Grand Prix LS4
Post
by ga93sle » Sat Oct 13, 2012 5:59 pm
Yeah, it can probably be fixed, but it's probably cheaper to buy a different rim...
*Chris*
15 Nissan Altima 2.5SL/2004 Honda Shadow 750 Aero
Previous, 07 GP SE, 06 GP GXP, 97 SSE 40th, 96 LeSabre Custom, 93 SLE, 90 LeSabre Custom
RogueSSEi
Posts: 569 Joined: Tue Mar 06, 2012 7:14 pm
Year and Trim: 98 Pontiac Bonneville SSEi
Post
by RogueSSEi » Sat Oct 13, 2012 7:00 pm
Yes it's repairable. I ordered some GP wheels that had that oxidized crud on it, been sandblasting them and they are turning out to look ok.
yonkerse
Posts: 1221 Joined: Wed Jun 02, 2010 7:16 pm
Post
by yonkerse » Sat Oct 13, 2012 7:04 pm
I had some with similar oxidation and mine were cleaned up with new tires installed. Been 20k miles and no leaks to this point.
Eric
2005 SLE, Greystone Metallic, 152K.
A few mods..
01bonneSC
Posts: 4938 Joined: Sat May 24, 2008 5:18 pm
Year and Trim: 05 Chevy 'Hoe 1997 'maro (3.8L M5) 89 SkiDoo
Post
by 01bonneSC » Sat Oct 13, 2012 7:26 pm
Drill with a wire cup works great.
00Beast wrote: Less off-topic than Lane's Heated Steering wheel, but yeah, back to the topic.
Posts: 26022 Joined: Mon May 19, 2008 6:04 pm
Post
by harofreak00 » Sat Oct 13, 2012 7:38 pm
Wire wheel it and then make sure the shop that mounts it uses a good amount of bead sealer.
SPLLOUDER
Post
by SPLLOUDER » Sat Oct 13, 2012 8:23 pm
Thanks for all the help !
Yes its Corrosion like the chrome started to bubble up badd and then water got in there and started making a aluminized corrosion impressions .
Ok so like a wire wheel on a corded drill . than maybe some buffing and make sure they use alot bead sealer .
i will be doing this sunday . i will keep everyone updated .
RogueSSEi
Post
by RogueSSEi » Sat Oct 13, 2012 9:33 pm
Yes that'll work. Use PPE of course.
SPLLOUDER
Post
by SPLLOUDER » Sat Oct 13, 2012 9:51 pm
yes i definitely plan on wearing my safety glass's and i have some mechanic gloves for sure
vogie01
Posts: 609 Joined: Tue May 25, 2010 10:20 pm
Post
by vogie01 » Sun Oct 14, 2012 2:05 pm
I had a rim that looked similar. Had the inside of it refinished and painted with a flat paint after it was cleaned up and I have not had any issues. It was sandblasted and painted.
2009 Ford Flex 63K [/u] My DD & super utilitarian vehicle that we call the White Bus.
2006 Honda Accord EX V6 Coupe 73k ; Wife's hot rod & highway ride.
SOLD: 2002 Bonneville SLE; 230K , Mods: Solid hockey puck front mount, Intense FWI intake, 180 degree thermostat, Magna Flow high-flow cat, ZZP O2 emulator: Nothing major but maintenance and what it takes to keep the dash lights off and the mileage up..
Posts: 20960 Joined: Tue May 27, 2008 10:30 pm
Post
by 00Beast » Sun Oct 14, 2012 3:53 pm
When I worked at a tire shop, we had a grinder with a wire wheel mounted right to the tire machine, and you spun the rim as you cleaned up the bead with the wire wheel. Cleaned wheels up perfectly.
Sirius wrote: Think about it. You’re tooling down the road in your Prius, knowing full-well that this thing being green is as big a sham as federally mandated ethanol-enriched gas, Russia pulling out of Ukraine, and Obamacare.
SPLLOUDER
Post
by SPLLOUDER » Sun Oct 14, 2012 9:03 pm
I Used the Crimped Wire Cup . Worked Great . But there is is some bad Pitting and scartch marks from me grinding .
Think it will hold up now ? i need to take some pics too ....
01bonneSC
Post
by 01bonneSC » Sun Oct 14, 2012 9:04 pm
Gob on bead sealer, you will be fine.
SPLLOUDER
Post
by SPLLOUDER » Mon Oct 22, 2012 8:04 pm
Ok i cleaned it up and took it back to the tire dude . and he said he don't use Bead Sealer .
I dropped it off and he remounted and said it still leaks but not nearly as bad .
Guess i have to find a tire dude that like bead sealer LOL
RogueSSEi
Post
by RogueSSEi » Mon Oct 22, 2012 9:08 pm
In your proof on the car, does air leak?
SPLLOUDER
Post
by SPLLOUDER » Mon Oct 22, 2012 11:03 pm
RogueSSEi wrote: In your proof on the car, does air leak?
Have not mounted it yet to car and see . will do soon
