After market Amp.
After market Amp.
I need to figure out where to put the remote wire for my amplifier. I still have my stock head unit.
Amp in question:
http://www.sonicelectronix.com/item_220 ... 400.4.html
I've had it in multiple places in the fuse box under the back seats, and it's been causing problems all the time. Killed an alternator, drained my battery multiple times... Is 400 watts too much for the stock amperage of the alternator? If you guys have any suggestions throw them out. I really want my music back.
sethjamesrimrodt
Year and Trim: 2004 GXP
Re: After marker Amp.
Post by sethjamesrimrodt »
400 isn't too much you should be good. Do you have monsoon?
Seth
Re: After market Amp.
Nah. It's an SLE, so it's got the Delco system I believe. No rear door speakers.
sethjamesrimrodt
Sorry man can't help you then
Seth
Alright no worries!
loudog1972
Year and Trim: 2000 SSEI Bonneville
Post by loudog1972 »
did u get it working ?
I mean I had the system working well for about 2 and half weeks. Then it ate my alternator. My lights were flickering. Sitting at lights in drive, the RPM's would drop to 500 and shake the car for maybe 1 second then go back up to normal. Then one night, I drove my car into a parking lot and parked it. Shut it off and locked it. Came back in 2 minutes, and the battery was COMPLETELY dead. Starter didn't even click when turned. As of right now, all I have playing music is my tweeters, since they're not on the amp circuit.
sethjamesrimrodt
So is the amp always on?
Seth
Well that's the thing. Where ever I'd put the remote wire in the fuse box, the amp would always show via LED that's it always on. Cause when it's off, it's got like a status light, and the LED is very barely illuminated.
loudog1972
where is the main power cable connected to ? also did the ac delco have an amp with it ? I am running an amp jumped off my Bose amp for audio input remote is being drawn from the fuses under the back seat and it has been working well so far no issues
sethjamesrimrodt
loudog1972 wrote:where is the main power cable connected to ? also did the ac delco have an amp with it ? I am running an amp jumped off my Bose amp for audio input remote is being drawn from the fuses under the back seat and it has been working well so far no issues
It does not have a factory amp...
Carl where did you end up hooking your scan gauge to? You could always run a wire from there, the amp does not draw much current for the remote turn on wire.
Seth
loudog1972
So its a basic old school install what i did was hit or miss till i found one that shut off with the ignition when i get a chance i will go out and tell you which fuse i tied into. I also went at it from under the fuse box with a clip
Thanks guys!
Seth, when I put the lead in where the Aeroforce went, it did not shut off with the ignition like the gauge did.
sethjamesrimrodt
nos4blood70 wrote:Thanks guys!
That is weird, I guess I would have to see it in person, sorry.
Seth
Oh well. Thanks anyways Seth. I'll get it eventually. It has to be something simple.
Figured it out. I hate myself for this one... Loose lead on the positive terminal on the battery. :banghead:
*sigh*
SSEiMan01
Post by SSEiMan01 »
Don't worry, I feel dumb too, I sat on that battery how long trying to figure this out? LOL
It really does explain what's been going on though. At least it was an easy, simple fix. Like always. :beerchug:
James May wrote:Hello.
