2000 SE Bonnie 141k back winder
- fritcr
- Year and Trim: 2000 SE
I had to say "winder" cause I'm from Missouri hahha JK
Anyway, the back driver window is down about 1/2 inch and will not go up or down. If mess with the switch it will make grinding/winding noises in there. I assume it needs a window regulator? (I swear I just put one in my bmw 2 weeks ago!) Anyway, is that hard to do? (providing that is what is wrong?) It was 14 this morning so I would like to get it fixed or at least up solid.
Rob
Rob
2000 Pontiac Bonneville SE Silver on Black Leather (Silver Streak) -144k
2003 Chevy Silverado LS Blue over Graphite (Old Blue) -184k
2001 Pontiac Montana Ext White over Tan Leather (Man Van) -wifes car -142k
1998 Pontiac Grand Prix GT Coupe Gray over Graphite (not named yet) -daughters car -157k
1996 Chevy Camaro RS 3800 Red over Graphite (Zoltan) -sons car -145k
- SSEiMan01
03 PAU - Location: DeKalb, IL
Re: 2000 SE Bonnie 141k back winder
Sounds window regulator to me...Not too bad to replace from what I remember of the ones on my brother's 01 LeSabre. I think there's a thread on here to serve as a how to.
EDIT: This shows a DIY fix for the regulator. http://www.pontiacbonnevilleclub.com/fo ... f=43&t=212
This shows Ebay listings for a new one, also try RockAuto: http://www.ebay.com/sch/?_from=R40&_trk ... Categories
Only thing is you're working in a back door, things may be tight. Not impossible though.
James May wrote:Hello.
- fritcr
Cool thanks! I had just started looking around again found that in the how too section. I will have to get it apart this weekened and see what I have.
Rob
I also found the fix for the seat heaters on there but I have a question. My lights never come on at all on either seat. In the DIY is says if they come on but go off after a few seconds. Mine never light up at all. Do you think it would still be the wires in the bottom seat?
Rob
- SSEiMan01
Could be maybe, I 'd check fuses first though.
- fritcr
I was going to check the fuses this weekend. It is 16 outside today...Burrrr..don't want to do anyting but sit by the fire when I get home. lol
Ken_W
- Posts like an L27
- Year and Trim: 2000 SSEi
You can get a new (aftermarket) regulator w/motor on eBay for $50. I put one into my rear driver-side door using the instructions here at the Club. It was not difficult (and I'm only an amateur mechanic). Works great now. It took me about an hour; would have taken less, but I had never done it before so I was slow and cautious.
Ken_W
Ken_W
Sorry for the dumb question but both my rear windows wont go up - so if I order the following it should cover everything I need to get my windows working again correct? When I use the switch a noise is made but the window just sinks down and wont go up.
00-05 Pontiac Bonneville Power Window Regulator w/Motor Rear RH Right Passenger (Fits: Bonneville)
00-05 Pontiac Bonneville Power Window Regulator w/Motor Rear LH Left Driver Side (Fits: Bonneville)
Ken_W
- Posts like an L27
@goochman: Yes, those are the correct parts. 90% chance that those will fix your problem. The other 10% covers the possibility of an electrical problem, which is less likely but not unheard-of. You can tell for certain by examining your current regulators -- if the cable is broken then you have your problem confirmed. Unfortunately, you have to take the doors apart to check this, so it might be better to just go ahead and order new regulators if you you need to drive this car daily. Your call.
Aftermarket parts are fine here. Get from eBay for best prices. The motors will be a little slower than OEM parts, but will not develop the same cable problem again in the future. If you want a faster motor you can swap out the motors from your old regulators -- very easy to do.
Ken_W
Ken_W
Thanks Ken - for $100 for both sides I just ordered the eBay ones and will have my mechanic install them Speed is not a problem and if it helps keep the cable from jamming in the future the betterKen_W wrote:@goochman: Yes, those are the correct parts. 90% chance that those will fix your problem. The other 10% covers the possibility of an electrical problem, which is less likely but not unheard-of. You can tell for certain by examining your current regulators -- if the cable is broken then you have your problem confirmed. Unfortunately, you have to take the doors apart to check this, so it might be better to just go ahead and order new regulators if you you need to drive this car daily. Your call.
Ken_W
