#1. Fuse for cig. lighter keeps blowing whats cause this??
#2 will hopefully replace abs module sunday what is the bleed order i need to go in?
2 questions
- samples08
- Posts like an L36
- Year and Trim: 2002 SSEi
88,000k - Location: Piedmont South Carolina
2 questions
Member #3848
Re: 2 questions
1) Overloaded circuit, bare wire, bad device plugged in, change in socket................just have to put a meter on it and do a good inspection.
2) With changing the ABS module, it will take several bleeds. You always want to work the farthest away from the master cylinder to the closest.
Right rear
Left rear
Right front
Left front
Go down a gravel road and lock them up to get the ABS to activate. Go home and bleed again as above. Repeat until clean fluid comes out of all 4 wheels and no air is present.
Doing this will bleed all the air out of the channels through the new module.
Right rear
Left rear
Right front
Left front
Re: 2 questions
i had a bad socket in one of my cars.. replaced the socket and it was fine. but could ba number of things.
Shane "RedZMonte"
2004 Z16 Z06: Virgin
