Just some minor mods:
Pioneer stereo that fits perfectly in the OEM opening.
Clear side markers.
Cold air intake(had to put padding under filter to keep it from banging-metal to metal).
8500K blue beams.
Hitch installed (carries my jet ski everywhere).
Well that's one *dang* good looking car. Too bad you're not a little further south...we need more south florida members! jees
John Now: '15 Toyota Prius III | 134 hp 2ZR-FXE | Silver | 36k
Now: '03 Honda CR-V AWD | Slow 4-Cylinder | Dirt | 180k Then: '07 Ford Fusion SEL | 221hp Gen I VVT Duratec 3.0 V6 | Tungsten Silver | 150k
I've got a similar Pioneer "fat face" head unit. I bought it new in '97, and it still works like a charm.
"GM cars run bad longer than most cars run at all"
(yes, I know, it's a crappy photoshop) '95 Bonneville SE -- mostly stock 2008 Chevy HHR LT '97 Grand Prix SE '93 Buick Roadmaster
wtf is "fat face"...? since when is double din referred to as fat face?
Just noticed the hitch....you have a transmission cooler right? If not...I suggest it..ESPECIALLY in the florida heat.
wjcollier07 wrote:wtf is "fat face"...? since when is double din referred to as fat face?
John, Bonnies didn't get double dins until 2k. These are din 1.5s...and that stereo is also compatible with Chryslers too.
That is a great looking car, but might I suggest building a heat shield for your air filter? You want to avoid drawing in hot engine heat as much as possible. If you can extend the pipe a little more to the front of the car to bring the filter closer to the headlight, it will help force colder air into it. Then build your shield and watch it go!
Towed a Uhaul trailer from VA to FL and never had a problem. Changed the Tranny fluid and filter recently and it looked great in there. I just tow my JetSki around now though. You mentioned the florida heat...check out the time on the clock and the temperature! http://www.pontiacbonnevilleclub.com/fo ... =9&p=29821#
