Loss of fuel mileage after tuneup?
AnthonySSEi
Year and Trim: 2001 SSEi
Post by AnthonySSEi »
i changed plugs and wires on my 01 SSEi and put in new ACdelco iridiums with Taylor 8.2 wires and i lost fuel
economy on the highway, could the wires be the culprit or maybe the plugs?
Roadtech195
Year and Trim: 2007 Grand Prix GT
Re: Loss of fuel mileage after tuneup?
Post by Roadtech195 »
are all your plugs gapped at .060 and are they the 41-101?
Are all the wires on tight?
2007 Grand Prix GT L32
Poly endlinks, swaybar bushings and dogbone bushings. Drop in high flow air filter. Its a start!
2009 Mitsubishi Eclipse GS (project BlackSheep) Bone stock for now, 5 spd and fun as hell! (Gf's Ride)
1996 Pontiac Bonneville SE Gone but not forgotten
1997 Dodge Ram Sport 4x4 5.9L The Beast!
AnthonySSEi
ya all at .60 and i jus checked if they were tight and they were, it doesnt make any sense.
TenGHz
Post by TenGHz »
How much loss did you get??
-Joshua-
AnthonySSEi
normaly i get 27 to 28 runnin 78-80mph , now its down to 24mpg at the same speed, same highway, same tire pressure and fuel grade 93.
Roadtech195
Is the fuel you are using blended with ethanol?
AnthonySSEi
ya actualy it was , the 7 11 station contains less then 10% ethanol, could that be it?
TenGHz
Post by TenGHz »
If you don't normally use corn, that could very well be the difference.
-Joshua-
AnthonySSEi
i hope thats what it is cus i dont feel like having to pull the plugs again until the next tune-up, those back plugs arent to fun to do.
TampaSSeI95
Year and Trim: 1995 SSeI Juiccccedd
Post by TampaSSeI95 »
yea if you did not use the corn before then thats your problem. i was tryin to stay away from the corn but now its everywhere i go
Only Race Cars Have Nitroussssssssss
You used Taylor wires? Be prepared to replace them in 6-8 mos.
wjcollier07
Year and Trim: ____
Post by wjcollier07 »
:stupid: That was not a very good decision for wires. Why didn't you ask here for the best suggested replacements beforehand?
Did you unplug your battery also after the tuneup? Its a longshot, but sometimes after the PCM has gotten used to a certain timing for old plugs and wires, it might try to lean towards it. Don't give it the chance..unplug the car overnight...doesn't sound right you'd lose that much efficiency just from that.
John
AnthonySSEi
ya i guess that was kinda stupid not to ask about the best wires possible, especialy since thats what ive used this club for since i started so i can see whats the best thing for our cars, what would u recommend i replace them with.
Roadtech195
Stock wires are fine or go to NAPA and get a set of Belden wires.
Or MSD, if you want the best, and something that will last. Use the Taylors till they go, you spent money on them, might as well use them.
AnthonySSEi
i disconnected the batt but havent taken it on the highway to see if it helped, but how much to the MSD wires run price wise and were can i find them for our cars.
Jegs; These. I believe these are correct, other wise, which ones are right?
AnthonySSEi
will i see any performance gains with the msd wires?
bonnevillain
Post by bonnevillain »
no. wires will not give you more performance unless they were bad in the first place. Even then they will just be restoring lost power
But they look better, last longer and are better than the stock replacements. And for not much more money, as well
