Is not calCulating 19mpg its more like 13. The fwi is 3.5od with 9 inch filter same I used on the
3inch spectra homemade. Should I unplug the battery an see if it will reload the info?
Here is a quick pix of the top of set up.
Avg...harofreak00 wrote:Are we talking instant or average MPG?
Couple maybe 3 to 4redzmonte wrote:how many miles have you drove with the change after you reset the MPG?
Shane
Dig00Beast wrote:How long had your average MPG been at 16? The more miles you have on it the harder it is to make it go up or down, more-so up. If you have 500 miles since you reset it you could drive for 10 miles at 100 MPH and it might change by .2. However if you reset it it will fluctuate greatly until it gets a few miles on it. This sounds like much adieu about nothing.
Are you refering to the MAF screen on the inlet of the TB with the retinaing Clip (BIG C clip)?JEzze wrote:?.. Does the clip and lil filter thing in the tb have to be there?
It should idle nicer too.JEzze wrote:I guess I will be putting it back in today.
