Hey guys here's my issue. I have a 99 sse. And the power seats won't move forward/back/up/dn. But the various lumbars work fine. When I push the buttons I hear a relay click up front but nothin from the motor except a noise like it wants to move but cant/won't. Any suggestions ?
Edit: after waiting a bit the passenger side seat works fine. It moves up n down even if the drivers seat is selected. Yet the inflator for lumbars still function correctly on the seat selected
no power seat movement
FireDevil
- Year and Trim: 1999 SSE
sonoma_zr2
- Retired Gearhead
- Year and Trim: 1999 SSEi
1997 SSEi-Resting-353K - Location: Montevideo, MN
Re: no power seat movement
The problem description is so flaky, the only thing I can recommend is taking the console switch assembly out and either replacing with a known good one, or taking the old one apart and cleaning. I actually diagnosed this same thing for a guy. He chose the take it apart route and it fixed it for him. He said as soon as he took it out he knew it needed cleaning.
Each seat has a control module, but when you gave your edited comment, that throws out the swapping module test. I would also advise you to check the ground buses under the carpet at the front edge of each front door.
FireDevil
Ill try the cleaning route. Any suggestions on what to clean with?
- crash93ssei
- Retired Moderator
- Year and Trim: 2002 SE
I also had a somewhat similar issue with my old 93, drivers seat would sometimes work when the switch was on the passenger position. Flipping it back and forth made it work right, I am sure the switch was just dirty.
- human
- Year and Trim: Daily Driver: 2011 Impala LT
Weekender: '95 Aurora - Location: Pines of Carolina
I don't know if they even still make the stuff, but it sounds like a job for TV tuner cleaner. You used to be able to get it at places like Radio Shack back in the days when TVs had big, manual tuning knobs on the front of them.
FireDevil wrote:Ill try the cleaning route. Any suggestions on what to clean with?
Weekend Toy: 1995 Olds Aurora
