weird feeling in steering wheel
- douellette88
- GXP Member
- Year and Trim: 2018 Toyota Camry SE
most of the time when driving my 97 ssei it feels like the steering wheel kind of like shakes back and forth (side to side) a little bit. to me it kind of feels like a cv shaft....does that sound right?
Hoping to return to an H-Body soon!
- RJolly87
Re: weird feeling in steering wheel
It could be. The first thing I would do though is rotate the tires and see if the issue moves.
~Randall~
viper8907
- Posts like an L36
- Year and Trim: 2000 SSEi
Try to pin point the wheel that is vibrating, then rotate the tires and see if the moves with the tires.
If it stays at the same wheel, it is most likely a CV shaft
If it moves, it's the tire itself.
If it gets worse when you apply the brakes, It is a warped brake disc.
-Tom
2003 Silverado Ext. Cab - Charcoal - 128,000 miles - Stock...for now.
2000 SSEi - Gone, but not forgotten.
Not always, there are a lot of things to cause a vibration. Tie rod ends, ball joints, rack and pinions bad or loose from subframe.viper8907 wrote:If it stays at the same wheel, it is most likely a CV shaft
If it is still there after rotating the tires, put it on jack stands and crawl under it and see if there are any loose suspension or steering components. Inspect the CV boots while there also.
viper8907
- Posts like an L36
Right, I shouldn't have said "Most likely", possibly would be a better word.myfirstbonnie wrote:Not always, there are a lot of things to cause a vibration. Tie rod ends, ball joints, rack and pinions bad or loose from subframe.viper8907 wrote:If it stays at the same wheel, it is most likely a CV shaft
If it says, it is an item to add to the inspection list.
-Tom
imidazol97
Does this happen at certain speeds? Low speed 35 and below? 55-65? 70 and up?douellette88 wrote:most of the time when driving my 97 ssei it feels like the steering wheel kind of like shakes back and forth (side to side) a little bit. to me it kind of feels like a cv shaft....does that sound right?
If it's noticeable below 40 on smooth roads, I'd go after the tires. Bad belts, dry rot? Wear?
- douellette88
- GXP Member
well the passenger side tire i can wiggle side to side (play)with it sitting on the ground! haha, but i gotta go check it again to see if its the inner or outer tie-rod,
