Fuel Filter STUCK
bobtaz13
Year and Trim: 2001 SSEi
1991 SE
Fuel Filter STUCK
Post by bobtaz13 »
When I first got this car running over a year ago I when to change the fuel filter. But with all my attempts it never broke loose. I am getting all the parts together for a tune up and really want to get the fuel filter changed this time. Here is a list of what i have tried.
I soaked it with brake free (over night)
Tried to brace it and hit it
Multiple wrenches
My new plan is to get flare nut wrenches and try that. I would like to heat it up red hot and try that, but something about that seams wrong (not sure why) . If you have any other tricks let me know. This thing is rusted solid.
2001 SSEi | Galaxy Silver | GenV supercharger P&P | Intense 3.2 MPS | Intense FWI 4"| Custom PCM | TOG Ceramic headers | Magnaflow 3" cat | 180° stat | Aeroforce scan gauge | PRJ plug wires | PRJ fuel rails | Silicone vacuum lines| AP103 plugs | 3.2 MPS | 42.5# injectors | Intense 1x cam kit | YT 1.8 Rockers | 105# springs | Meziere HD pump | N* Tb | 185mm MAF | 2" Phenolic Intercooler | Oil pressure kit | L32 short block | 5% overdrive SFI Balancer | L67 heads custom ported | EBC USR Rotors | EBC Red stuff pads | Custom HID Fog lights, with HI-beam over ride | Polyurethane motor mount | Energy Suspension end links | GXP Shocks/Struts | Custom Drop springs Front, Rear FE5 Springs | GXP Strut tower Brace | GP GXP 18x8 Rims | Polished Exhaust tips | Triple Edge High Performance Street/Strip 4T65E-HD |
Re: Fuel Filter STUCK
ALWAYS had luck with 2 large vice grips.
Ya, don't use heat.
RJolly87
1994 Buick Regal Custom
Post by RJolly87 »
Keep hitting it with PB blaster.
I am certainly loving the C-Body fuel filter configuration right about now :wink:
~Randall~
BWP-ssei
Year and Trim: 1993 Pontiac Bonneville ssei
Post by BWP-ssei »
Please, only use the flare wrences if possible. Every other type of wrench will only round the nut off. Last time I did the fuel filter it had quick-release for both sides of the filter, but mine is a 1993.
LeSabre in Buffalo
Year and Trim: 2012 Eco
Post by LeSabre in Buffalo »
Try some CRC Freeze-Off. It freezes the joint to break the rust bond so you can get it. I'll be seeing about that claim in a few weekends.
Or if you want it off now, use acetone and fresh ATF in a windex or similar bottle and use that. I've seen independent tests that say it takes 4x less torque on a rusted nut than PB Blaster. Like LeSabre in Buffalo, I have yet to try the claim.
zuper8
Year and Trim: 96 SSEi- 157K
Post by zuper8 »
ed, what's the ratio of acetone to atf? 50/50? gonna try it on MY stuck fuel filter lol. vice grips just chewed up the nut.
- Rachael
Yeah, half and half. Forgot to mention that, lol. Shake it up real well, and don't get it in your eyes, lol.
LeSabre in Buffalo
The Freeze-Off worked too well. It broke free the junk holding the fitting to the filter, and I'm leaking gas. Off to the parts store for the Dorman repair kit and a tubing bender.
BTW, compression fittings are legal in NY, as per my reading of what they inspect. They don't care if it's held together by black magic if it's not leaking/dripping/puddling.
bobtaz13
1991 SE
Post by bobtaz13 »
I tried CRC Freeze-Off, but i broke the line right befor the filter. When to NAPA and they had a repair kit just for that problem. Thanks for the input guys
