tranny prob?
- gonzo4191
- Year and Trim: 91 S10 P/U
97 SSEI- 136k - Location: round lake beach, IL
tranny prob?
alright here's the problem, some times when accelerating from a stop will cause car to just about die. then when around 50, the car will like will shake and have no power, till i goose it, feels like a rev limiter
airdvr1227
- SSE Member
Re: tranny prob?
I don't know the answer but my experience has been engine problems on the freeway can feel like tranny problems. I'm betting it's not the tranny. Sounds like a fuel delivery issue.
- Pontiacdad
- Retired Gearhead
- Year and Trim: 2000 SSEi
Re: tranny prob?
I agree it does not sound like a tranny issue.
Rarely see fuel being an issue at speed.
Hows your ignition system, when was the last time the plugs and wires were changed?
Bone Evil
Mods: Tog Headers, cat delete, Al 104's gapped .050, 1.9 rockers, 105 springs,
Intense FWI, DHP Power Programmer PCM, Intense tranny with gen2 lsd,
Aeroforce scan gauge, Clear front and back, N* TB & LQ4 Maf,
Hoosier slicks, ZillaMotorsports P/P GenV & LIM
Pisco_Paul wrote:Every time you pat my head, you pat a piece of my valve retainers.
- gonzo4191
Re: tranny prob?
wow when did you guys respond
plugs and wires about 2k ago
- Pontiacdad
- Retired Gearhead
Re: tranny prob?
They are still suspect and should be checked out, use an ohm meter on the plug wires and a visual of the plugs including checking the gaping.
Bone Evil
- gonzo4191
Re: tranny prob?
did both, the gap was at .50, so put that at .60 and i'll get a meter soon.
Re: tranny prob?
Clean or replace the MAF. I had the same issure two weeks ago... almost feels like the car dosn't know which gear it wants to be in at higher speeds, and wants to die from a start. Replaced MAF, took care of issure. Snap on scan tool showed that when the roughness was there, the MAF was actually showing like 76000 hz. then drop to 0 for a moment. Never set a check engine light.
