1999 SSE L36 110,000 miles.
At idle, gauge is at 40 lbs. Under throttle it is at 60 lbs. Is this about what it should be?
What is acceptable oil pressure?
Barry
- Posts like an L27
- Year and Trim: 1999 SSE
1999 SSE. 112k, Cleared Corners, Mobile 1, Energy Suspension endlinks. Ported and Polished LIM, NGK TR-55 Sparkplugs, 180 drilled Intense stat, Flow matched injectors, Intense FWI, Intense PCM, MagnaFlow Cat.
- J Wikoff
- Year and Trim: 1992 SSE
Re: What is acceptable oil pressure?
Sounds fine.
Thats dead on the money for a 3800 in good shape
Barry
- Posts like an L27
Thanks. The car runs great. I just had never read what the acceptable readings were, and was curious if mine were in range.
