Ding Ding Ding..
mntnbkr
Year and Trim: '99 SSEi
Re: Ding Ding Ding..
Post by mntnbkr »
I'm pretty sure they can test the alternator while it's still on the vehicle, with the vehicle running. At least my parts store can.
~Adam
'99 SSEi
'02 Volvo S60 AWD 2.4T
'02 Jeep Liberty Sport
'89 Chaparral 187XL w/ 4.3L I/O Mercruiser
'00 Cannondale Jekyll 900SX
Follow me on twitter: adumb
m1030w6
Year and Trim: Name: Nick
[b]1998 Pontiac Bonneville SE [/b]
Post by m1030w6 »
okay doesn't hurt to try and that 1st if they say no I can just come back home and take it out...
thanks
- Nick
edit.. just got back from getting the alternator tested and if tested fine.. next step I think I will look for a loose wire or a wire that's grounding itself in the firewall...
Car: 1998 Pontiac Bonneville SE
olblueeyesbonne
Year and Trim: 99 SSEi
01 SLE
02 GTP40th
02 SSEi
06 GP GT
Post by olblueeyesbonne »
Just take a light bulb for the empty headlight connector and plug it in. If that stops the dinging, problem solved.
DHP Powrtuner & Tech 2
1998 GTP Coupe
1999 SSEi 70k miles
2001 SLE
2002 GTP 40th Anniv Ed Coupe
i<3bonbons
Year and Trim: 1993 SSEi
Post by i<3bonbons »
my se used to ding, it was the coolant, once i filled it the dinging stopped.
finalm6
Year and Trim: 1993
SSE
Post by finalm6 »
Hey I have a 93 SSE and I’m getting the same ding ding ding every time I accelerate or and brake, the only difference is my brake light on the dash is on. does anyone know what could be causing this I tried pushing the brake all the way down then releasing tried lifting my brake pedal up but nothing is helping any help would be greatly appreciated. THANKS.
Maybe this might help you maybe your brake light is out.
CAR: White 1993 Bonneville SSE
olblueeyesbonne
01 SLE
02 GTP40th
02 SSEi
06 GP GT
Check your brake fluid level in the reservoir, as well as below it on the firewall -my bet is your master cylinder is out.
1998 GTP Coupe
1999 SSEi 70k miles
2001 SLE
finalm6
Year and Trim: 1993
SSE
Post by finalm6 »
Hi I checked my braked fluid today it was a little low about an inch below max. I’m going to the auto store tomorrow to get some and top it off. But my question is if my master cylinder is out wouldn’t I feel it having some kind of effect on my braking? (Not sure) . Because the car stops really good and if I put my e-brake I can’t even move the car. Thanks for any help or ideas in advance.
2000Silverbullet
Post by 2000Silverbullet »
The emergency brake is totally independent from the hydraulic system.
Usually when a master cylinder goes, the pedal will sink to the floor and braking power decreases.
finalm6
Year and Trim: 1993
SSE
Post by finalm6 »
2000Silverbullet wrote:The emergency brake is totally independent from the hydraulic system.
Ok so any clue at all why the brake light comes on and the dinging begins lol. it actually wont stop now I’m going crazy trying to figure out what is going on. :eek2:
sandrock
Post by sandrock »
Hold on here....
The constant "dinging" like that is indicative of a light bulb fillament touching one of the contacts, and not fully attached to it. So...you might want to check your tail lights AND the center-stop light. AND...check your license plate bulbs.
2000Silverbullet
Also check the electrical switch on the emergency brake. It could be stuck on, like the brake is always on.
Cheetah
Year and Trim: 97 White Ei 197K
97 Black SE/SC 185K
Post by Cheetah »
Check your trunk switch. Or see if it dings with the car running when you open and close the trunk.
Check every fuse in your fuse box.
Cheetah
97 Black SE/SC 185K
Post by Cheetah »
m1030w6 wrote: tonight while drive home it has gotten worse now, with the ding ding ding all the light will flicker on and off like crazy and it does this randomly, and the battery gague will go all the down to the red.
Was it just the battery gage, or all the gages. Did any lights on the dash flash when this happened?
finalm6
Year and Trim: 1993
SSE
Post by finalm6 »
finalm6 wrote:Hey I have a 93 SSE and I’m getting the same ding ding ding every time I accelerate or and brake, the only difference is my brake light on the dash is on. does anyone know what could be causing this I tried pushing the brake all the way down then releasing tried lifting my brake pedal up but nothing is helping any help would be greatly appreciated. THANKS.
Hey everyone i checek the brake fluid it was a little low and i added some brake fluid and the dinging stoped so that is a heads up to anyone with a similar proplem. and thank you all for all of the help and ideas. :banana:
