sunroof air deflector broke...
Ryno02
- Posts like an LG3
- Year and Trim: 2002 Bonneville SSEI(sold)
wasnt expecting this last night. i was closing my sunroof and it stopped half way. i opened it back up, and the black "air dam" that pops up when you open the sunroof is broken by the passenger side hinge point. are these replaceable, and where can i get a replacement if it is?
~Ryan, 2002 bonneville ssei(sold)
01bonneSC
Re: sunroof air deflector broke...
Theres supposed to be a dam that pops up? Any pics?
I think previous owners and had problems with the sunroof on my car, never seemd rright since ive had it with a lot of rattling, etc. Thinking it has been replaced before. Im gonna keep an eye on this thread.
dustpusher
- Year and Trim: 2000 SSEi
I have a 00 ssei and took mine off when it broke.It opens and shuts fine without it.
Mine was broken when I bought my car. Been like that for years. I honestly think its quieter with the deflector held down anyways (in other cars).
AFAIK, the only way to fix the problem is to drop the headliner and completely remove the sunroof track. maybe even have to replace the entire thing.
ddalder
I take mine off regularly to clean the bugs and stuff off. Gentle handling is all that's required. Should be able to find one easily enough. If nobody on the forum has one you could definitely get one at the dealer (although it would likely be expensive).
beachbum
- Year and Trim: 2000 SSEi, Bronzemist, Original owner.
I had the same problem on my 2000 SSEi and went to gmpartsdirect.com and ordered one that was easy to install. They delivered the part promptly and I was very satisfied. Good luck.
2000 SSEi - Dark Bronzemist, stirred but not shaken', original owner with 85K miles, every option available except heated seats..(not much use at the beach!).
alexcoqui
- Posts like an L36
- Year and Trim: 2001 Blue SLE - 2001 Black SSEI - 2005 Grey Aztek
Mine broke on the drivers side a few month back while I was closing it. & I havnt opened the sunroof ever since. Guess Ill rip the piece off when I get home & have a sunroof again.
2001 Blue SLE - 1995 Black SSE - 1988 Black GTA
Ryno02
- Posts like an LG3
yeah, i wouldn't mind just removing it if i can and the sunroof operates normally. it will just be a bit windier, but i like that.
dustpusher
I didnt notice much diff with it on or off.I dont think it did much with it.
Ryno02
- Posts like an LG3
woot! that was easy. it just clipped off after i unhooked it from the front part of the roof. there is a definite low freq. hum from the wind on the open sunroof now at mid speed. i might try to get a replacement, its annoying.
01bonneSC
Crack your rear windows and the droning subsides
sonoma_zr2
- Retired Gearhead
- Year and Trim: 1999 SSEi
1997 SSEi-Resting-353K - Location: Montevideo, MN
if you want a breeze, adjust the right rear window. Do the left rear if you don't, if you have a passenger they will get the breeze. Leave the fronts up and don't do both rears at the same time. OK, try it once to experience it, then don't do it again01bonneSC wrote:Crack your rear windows and the droning subsides
Ryno02
- Posts like an LG3
D'oh. didnt even think about that. dur. thanks.
Ryno02
- Posts like an LG3
*dang*, its still doing it. time for a junkyard search. gm parts direct has it at $42 bucks
