http://www.pontiacbonnevilleclub.com/fo ... f=20&t=851
I started tearing it down today. Got as far as removing the intake manifold and valve covers. Tomorrow I will have the front cover off. Currently the waterpump and everything else is off the front. I need to drain the oil and remove the pan next.
Here are the pics:
Before the work started
Looks like I need a new grommet (haven't looked for the other half yet
TB removed
Fuel rail
Inside the intake
Bottom of intake
From the top
The good stuff:
Looks like there is room for some porting. There is also a question of this motor being apart before. Did Felpro make OEM gaskets? There is also evidence of these plastic gaskets deteriorating also. Here are the gasket pics. Will try to get better ones tomorrow.
