New AC in a 92 Bonneville
The ac in my 92 Bonneville is shot. I basically need an entirely new system to include the compressor, condenser etc. The entire job is going to cost me $1,400. Putting this kind of money into a car this old probably isn't the most logical thing but I really like the car and plan on keeping it for another three years ... maybe more (it has 204,000 miles on it and I only drive about 8,000 miles a year). This is quite a bit of money to stay cool for a couple of months out of the year. Before I do this, I'm giving you an opportunity to talk me out of this and or provide some ideas as to how to save some money on this job. Thanks!
2002 Ssei- 180,000 mi
2006 Cadillac STS AWD
1992 SE - 214,000 mi - Traded 12/2009
Re: New AC in a 92 Bonneville
How can you have an 02 SSEi and still "really like" the 92 SE enough to drop $1400 into it.
You could buy a car exactly the same (maybe even an upgrade from the 92 SE) for $1400.
http://minneapolis.craigslist.org/cto/1133692238.html
I know exactly what you're saying. It's not logical but..... I know my car and I do like it (I do drive the 02 Ssei quite often though). It fits my butt perfectly. I had the tranny rebuilt about 60,000 miles ago and had some engine done ... . I've thought about buying a 98 or 99 but they are all high milage and ya just don't know what your getting with the kind of mileage on these cars. Like I say ... it's not very logical.
wjcollier07
- Year and Trim: ____
If its not rusty...then its completely worth it if you plan to keep the car... its normal maintenance in that regard then
And I can personally completely understand loving an older SE just as much as, if not more than a newer car. I know its true with me.
So, compressor, condenser (probably pretty well rock damaged by now), your evaporator will need cleaning, accumulator, orifice tube, cleaning solvents, oil, and refrigerant. $1,400 is definitely going to be minimum, if you do everything yourself.
John
I wasn't going to do it myself..... I'm not that technical. I'm having it done by a local shop. Are you saying it would cost me $1400 if I were doing it myself? The quote I got included $1052 in parts and $360 in labor for a total of $1412.
Here is the estimate I was provided
Compressor $ 480
condenser 175
orifice 10
accumulator 52
hose assemb. 180
flush system 31
seals 35
oil and dye 30
fittings 20
misc 40
labor 360
Total 1412
Compressor $ 480
condenser 175
orifice 10
accumulator 52
hose assemb. 180
flush system 31
seals 35
oil and dye 30
fittings 20
misc 40
labor 360
Total 1412
I just bought all these parts to replace my ac from an online vendor discountacparts.com for less than half of the price the local shop quoted for parts which includes an oem compressor ....
I either bought some cheap *ss parts or the local shop was gouging me. I suspect it may be a combination of both. I got the compressor, condenser, orifice, accumulator, seals, and oil for $470.
Believe it or not, the local Pontiac dealership that'd a done some work for me in the past said they would install the ac components and charge it for me. We didn't talk price but I was floored when they said they would do it. Although, I bought front brake rotors and pads for my 2002 Ssei and they performed the installation for $89. No more than the tire shop was going to charge.
LeSabre in Buffalo
- Year and Trim: 2012 Eco
It sounds like they're being reasonable, so go for it! They must be hurting for business, or an old-timer is raring to have a crack at something they've not done in a while.
- mstrwolfgang
- GXP Member
- Year and Trim: 92 Bonneville SE
Strange, I got my A/C compressor replaced, system converted off of R12 freon, and a freon recharge for under $500, parts AND labor. The only thing I can think of was that my new compressor was a re-man. Just my 2 cents...
P.S. It was the great Tire Mart down the street that hasn't let me down yet.
92 Bonneville SE
175K and still ticking...
Master Wolfgang
Master Wolfgang
malatu wrote:I just bought all these parts to replace my ac from an online vendor discountacparts.com for less than half of the price the local shop quoted for parts which includes an oem compressor ....
Yeah if you search you can find the parts pretty reasonable... I bought my parts that way for the Van... I think I spent $300 Total... It really wasn't bad and I had cold AC all last summer... The system was still cold when I retired the motor.. After I did all of the work I never had to charge the system.. It stayed within specs( meaning no leaks )...
I'd let the dealership do it if the price is reasonable
tz2772
- Year and Trim: 1990 LeSabre
AC is great when it works isn't it!! Mine has stopped blowing cold in the last week and a half or so.
1990 Buick LeSabre Limited 100k - Black Sapphire Metallic
Mods:
Strut Tower Brace, Type II Delco Ignition with MSD Coils, Delco 140 amp alternator, 89 Electra/PA CD Player, Audiovox CommanderMT XM Radio, V08 HD Cooling Radiator with Second Fan, 3/8" Transmission Cooling Lines, B&M Aux Transmission Cooler, F41 Front & Rear (Air) Struts, F41 Front & Rear Sway Bars, 96-00 Buick LeSabre/PA 16" wheels and tires, 89-91 SSE Console/Shifter, Class II Trailer Hitch and Wiring, $1000+ in Second Skin Sound Deadening Material, LeSabre T-Type Cluster, 91-92 Buick Century Steering Wheel Controls. Amsoil SSO 0W30 and Amsoil ATF.
Next: Cadillac FWD V8 Braces, F41 Springs, 1988-1991 Olds A/W/C/H -body Driver Info Center (already wired, waiting on a mount)
2003 Mercury Grand Marquis LSE 153k - Silver
Mods:
Pioneer AVIC X910BT Navi, 2010/2011 Mustang 18" Wheels, Class III Trailer Hitch and Wiring, Amsoil in Engine, Trans, and Differential. Damaged Jan 2012 - waiting on adjuster to determine fate -
Mods:
Mods:
Matt, shoot it with some R12 if you can find any or a shop that will do it for a reasonable price..
R12 work very good for a long time... It still blows cold even when a bit low.. R134 is touchy..
- Whitecrystal1
- Posts like an L36
- Year and Trim: 10 Silverado
I dumped around $800 in repairing the ac in my 95 around 2 years ago... I don't regret it at all. Even if you can buy another car for around the same cost, as you already mentioned, you never know what your gonna get. I vote for fixing it if everything else is in good shape and as you said your planning on keeping it a couple more years.
2002 Buick Lesabre Custom L36 Titanium Blue Metallic/Medium Gray Cloth
2004 Buick Lesabre Custom L36 White/Graphite Gray Cloth
2015 SS Roof, Spare & 6M 6.2L LS3 415HP/415TQ SLIHRM/Jet Black Leather-Red Stitching
2010 Silverado LTZ Crew 4x4 6.2L L9H 417HP/403TQ NHT Black Granite Metallic/Ebony Leather
2013 Enclave Premium AWD 3.6L LLT White Diamond Tricoat/Cocoa Leather
2001 Wellcraft Martinique 2400 Merc 5.7L BIII 327hrs
1995 Bonneville SSE L36 Dark Polo Green Metallic **R.I.P. 4/28/10 236,400 miles**
I've ordered the parts and don't regret it one bit. I'm gonna keep the sweet-heart road-worthy regardless of her monetary value! I don't think I've made that kind of commitment since I asked by wife to marry me (I bought the car long before that moment!).
