project 40th
Part it or fix it?
Part it out
21
30%
Fix it up and sell it
48
70%
Total votes: 69
dbeast420
Year and Trim: Sapphire -1999 SSEi Metallic Navy Blue
Re: project 40th
Post by dbeast420 »
I swear,you could polish a .05 turd and turn it for 100.00 :hail:
fuelforthesoul1999 wrote:Sapphire, of course, god that's the automobile equivalent of Halle Berry, you just want her.......
Without question, the greatest invention in the history of mankind is beer. Oh, I grant you the wheel was also a fine invention, but the wheel does not go nearly as well with BBQ!!
swampthing
Re: project 40th
Post by swampthing »
harofreak00 wrote: After that, only a few issues remain: Mounting the new truck latch and replacing the grumbling motor mount.
sounds like somebody's got truck on the brain :laughing3: this is an awesome turn around to watch it must be immensely satisfying at the end of the day to know that car looks like that because of your hard work.
Current fleet:
ddalder
Re: project 40th
Post by ddalder »
That's some mighty fine work there, Andrew! Looking VERY nice! Bet you're glad now that you didn't go ahead and part it out ;)
ohenry5
Year and Trim: 1997 SSE 40th Anniversary
Re: project 40th
Post by ohenry5 »
Andrew, you are the man! Nice work. Gosh I loveee the 40th in that color!!! (I'm not biased at all, lol)
1997 SSE 40th Aniv. Dark Cherry Met., 35% tint all around, Chrome T-Stars, stock everything else
crash93ssei
Re: project 40th
Post by crash93ssei »
Looking good for sure! The Porter Cable buffer will do an excellent job for you, but be warned. You will very likely end up addicted to what it can do. Even a very light polish will make a huge difference in what the car looks like.
If you are going for perfection, be prepared to spend about 12 hours on the exterior alone. A quick and simple single stage polish would probably take about 3 - 4 hours but will still leave the paint looking absolutely amazing.
Do you know yet what you are going to be using for polish and pads yet?
pokey
Year and Trim: 1995 SE
Re: project 40th
Post by pokey »
Man, that is looking fantastic! Excellent work!
"GM cars run bad longer than most cars run at all"
(yes, I know, it's a crappy photoshop)
'95 Bonneville SE -- mostly stock
2008 Chevy HHR LT
'97 Grand Prix SE
'93 Buick Roadmaster
TenGHz
Re: project 40th
Post by TenGHz »
Wow, great work. Looks like new!
-Joshua-
wjcollier07
Year and Trim: ____
Re: project 40th
Post by wjcollier07 »
Looking utterly fantastic.
Quick question Andrew..
Do you, have you, or are you going to follow up the magic eraser cleanup with a high quality conditioner like lexol? They look fantastic, but it would be pretty sad to see any cracking start from lack of conditioning.
John
Re: project 40th
PSST, I have Lexol. :wink:
Re: project 40th
I have Megs leather conditioner, already applied it.
Re: project 40th
Did this today: http://www.pontiacbonnevilleclub.com/fo ... 16#p118216
Well I tinkered on the car a lot today. I got the mount replaced quite easily, I'm glad I didn't drive to Ed's to use the lift, it would have just made things harder LOL.
The front mount was definately shot, but it wasn't causing the grinding. I took it for a test drive immediately after the swap and it was exactly the same. I was pretty sure its not the rear trans mount, so I didn't even mess with it.
I took another look at the TAM mount and decided to take it off to have a better look. It came out pretty easily and I noticed that the metal "tube" was amost completely seperated from the rubber. Looking at how this mount is designed to work, I figured the way it was failing shouldn't be causing the grinding. The engine is pulling down on the mount. However, when the engine is accelerating, the engine rocks back and the TAM actually rubs against the metal engine bracket. I REALLY want to narrow this down, but I don't wanna be tossing money on this car like its nothing. Rockauto wants $41 for the TAM, reasonable. Right?
After getting the mount fixed, I took it for a longer test drive than normal. I got it up to temp for the first time. I pulled into the driveway at home and noticed there was a coolant leak. After the thermostat opened it caused a leak high up on the side of the radiator (the plastic part). I put a couple layers of JB Weld on it, hopefully that holds, I don't feel like getting a new radiator, I just sold my parts car one...ugh.
The car still isn't running 100%. It seems like the MAF is bad, because I can unplug the connector and the idle doesn't change. I swapped in 2 other known good MAF's and it doesn't change either. Maybe I should try some new plugs, who knows how old they are. The wires look new... there is even new dielectric grease on the coils!
I was at the point today where I just want to sell the car, I'm sick of working on it. Gotta keep plugging on... can't give up.
ddalder
Re: project 40th
Post by ddalder »
Hang in there, Andrew. You`ll work through this... you always do :wink:
We`ve come to know the top quality work you do!
Re: project 40th
Replaced the TAM today. The grinding is completely gone.
After I fixed the mount, some more problems came into view. The engine still isn't running right. It doesn't sound like a miss, it just doesn't have any power. I swapped out the spark plugs and wires. Didn't change.
crzydmnd72
Year and Trim: 1999 SLE
Re: project 40th
Post by crzydmnd72 »
Just my .02. When I got rid of my Malibu, it had less power than when new and it had been throwing Catalytic codes. General consenus was a plugged cat. never fixed it, just got rid of it. Just didnt have any oooomph anymore
Glenn
1999 SLE 70k Stock for now
Re: project 40th
Good idea... I'll look into that.
petraman
2013 Audi A4 6MT
Location: ............ Granville, Ohio/Erie, PA *WCBF '08 SURVIVOR* *NEBF '07 SURVIVOR*
Re: project 40th
Post by petraman »
Keep plugging away, Andrew! You've come this way, it would suck if you gave up now...
http://www.youtube.com/watch?v=VZ2HcRl4wSk
2013 A4 P+ ------------------ Glacier White Metallic
6MT, Sport Pkg, JHM Stage 1 Clutch/LWFW, JHM Short Shifter, JHM HFC, USP SS Clutch Line, CR-15 Strut Bar, Alu Kreuz, BFI Shift Knob, EC Trans Mount Insert, VCDS tweaks.
Skippy1827
Year and Trim: 2015 Cadillac XTS
Re: project 40th
Post by Skippy1827 »
go, go, go
Steve
Re: project 40th
I pulled the exhaust off and took it for a drive (loud!). Still not getting the power it should.
The cat looked fine.
petraman
2013 Audi A4 6MT
Re: project 40th
Post by petraman »
Uhh, this has probably already been discussed... But have you changed your O2 sensor out recently? It looks like it's been running pretty dang lean... Check fuel pressure? I know my car ran pretty bad with a bad fuel filter...
crzydmnd72
Re: project 40th
Rats, sorry the cat wasnt it. OTOH, I'm glad it wasnt it. They wanted 250 bux to change mine lol.
Glenn
