project 40th
Part it or fix it?
Part it out
21
30%
Fix it up and sell it
48
70%
Total votes: 69
Re: project 40th
I had to special order them, but they were there the next morning.
Re: project 40th
Got the car back this morning. I am very impressed with how it turned out.
The seam is right under this rubber seal. I'll remove it and paint up to that line.
I still need to put that door seal back on that covers the rust on the wheelwell.
Here is how the trunk lid turned out. He did a great job. He used a thicker metal plate than the stock sheet metal, so I won't have to use any backing nuts. I just have to align the latch in the correct position. For some reason I think I'm going to be sitting in the trunk for this one.
ohenry5
Year and Trim: 1997 SSE 40th Anniversary
Re: project 40th
Post by ohenry5 »
Not bad, not bad at all.
1997 SSE 40th Aniv. Dark Cherry Met., 35% tint all around, Chrome T-Stars, stock everything else
GoldenBullet
Year and Trim: 2001 GMC Yukon XL
Re: project 40th
Post by GoldenBullet »
That turned out pretty well.
-Matt
labonnevillastrangiato
Year and Trim: 1993 SSEi, Red Bonnechetta
2003 GMC Envoy SLT
Re: project 40th
Post by labonnevillastrangiato »
I'm rather impressed, Andrew.
Once you throw on some touch up paint, it will look quite seamless.
Prior to putting the seal back on in the wheel well, and touching up the new rocker, perhaps some rust preventative primer first as prevention? Or, for maybe the wheel well, a few sprays of undercoating from a can?
Can't wait to see the finished product!
Adam
1993 SSEi "Red Bonnechetta" COTM July 2014
2003 GMC Envoy SLT
ohenry5
Re: project 40th
Post by ohenry5 »
Any news on this or is the Park Ave getting all the attention right now?
Re: project 40th
Been really cold/rainy the last few days. I haven't been working on either car. We were in the high 60's and now are well below freezing. UGH.
blackout
Year and Trim: 96 Bonneville SE
Re: project 40th
Post by blackout »
if you part it i want the bumper covers and rear trunk light
96 SE Pioneer AVHP5700 head unit(ipod connection) new are intake, clear corners, new foglights. HID head lights (Soon to have new rims) as soon as it gets warm enough.
Re: project 40th
This car is definitely not getting parted out.
ohenry5
Re: project 40th
Post by ohenry5 »
Yea i hear you on the change in weather, it was 60's-70's here, now its rainy and getting some snow tomorrow. Thats early spring for ya!
Re: project 40th
Worked on the car quite a bit today. I didn't take any pics of the progress, but I'll get some up soon.
Got the airmix actuator swapped in, works great.
Swapped the visors.
Swapped the vents.
Swapped the power antennas.
Swapped the steering wheel controls.
Swapped the glovebox latch.
Swapped the 6x9s and door speakers.
Tomorrow I'm gonna pick up some undercoating and spray the bottom of the new rocker molding. Than I'll put a couple layers of paint down and get the rocker molding in place. I am borrowing a nice Porter Cable random orbital polisher to tackle the exterior. After that, only a few issues remain: Mounting the new truck latch and replacing the grumbling motor mount.
TenGHz
Re: project 40th
Post by TenGHz »
Wow, the body work looks pretty good. I'd be satisfied. You'll have that thing looking great by the time you're done with it.
-Joshua-
laxmangl
Year and Trim: 2000 SE, 2008 Trek 3700
Re: project 40th
Post by laxmangl »
I can't wait to see this thing when it's all finished. Is there any news on weather you will be keeping it in the family?
2000 SE: 17" Chrome Grand Prix GTP wheels, Pirelli P-Zero Nero Rubber.
180,000 miles and running smooth :)
Re: project 40th
Looks like it won't be going to family. I've put to much into it to watch my brother trash it. (yes, he would do that)
PRD2BDF
Re: project 40th
Post by PRD2BDF »
Don't blame you at all. It's starting to clean up nicely.
2000Silverbullet
Re: project 40th
Post by 2000Silverbullet »
Now you can imagine how I feel about the Grizz in the hands of an 18 year old son. :angry7:
The new front tires are beginning to round off. :eek2:
.....and last week he lost the gas cap!
GoldenBullet
Re: project 40th
harofreak00 wrote:Looks like it won't be going to family. I've put to much into it to watch my brother trash it. (yes, he would do that)
is this the same brother that had the camaro?
-Matt
Re: project 40th
Yup. However, he doesn't drive it much thankfully. He has a 95 GrandAm and 98 Blazer as daily drivers. They are both gross.
Here are the pics.
New vents... ya one is broken, but its better than what it replaced.
New dash vents, and glovebox latch
New visors
New power antenna
New steering wheel controls
crzydmnd72
Year and Trim: 1999 SLE
Re: project 40th
Post by crzydmnd72 »
Man, if the sellers could see that car now.
Sure appreciate the way you fix em up with original parts and keep em mostly original or with tasteful upgrades.
Glenn
1999 SLE 70k Stock for now
Re: project 40th
Finally! A beautiful day to work on the car. It was about 50*F and sunny.
I sprayed the pinch weld with some rubberized undercoating, let that dry, and then gave a few heavy coats of the color matched paint. It came out RED at first, but after a few coats, its perfect.
Rocker molding clips go into place…
Mounted…
Here is before I put that rubber weatherstripping in place…
And completed…
Also replaced the clips on the passenger side. I did find some minor rust under there, but not near as bad as the other side.
After that, I turned my attention to the trunk lid. I sat in the trunk while I had my roommate held the trunk shut. I marked the holes to drill and then drilled them. I mounted the latch and tightened it down. It closed and opened perfectly the first time!
So, this is how the car looks now…
Left to do:
Tackle the exterior: wash, polish and wax
Fix that dang motor mount or whatever that is making the grinding noise (still cant figure it out)
