hmm, rocker time
MadMike
Year and Trim: 2003 Bonneville SSEi
hmm, rocker time
Post by MadMike »
i wanna drop some rockers in
but
i need a solid parts list, and i cannot find a thread with one to save my life
so far i got. . .
Yella Terra Roller Rocker & Pushrod Package 1.8
Crow Cams105# Valve Springs
CompCams High Performance Valve Locks
Viton® Valve Seals
im not sure what else ill need anyone wanna chip in some insight?
Miles: 80k - Color: Maroon - Rims: aSa sport CD - Tint: 5% ^-^ - cleared fronts - ebay blue high/lowbeams - custom amber turn signals
247whp301chp321tq - 3.4 MPS - Brian Tuned PCM - FWI w/ 9" K&N - 3/4" TB spacer - Alternator Voltage booster w/ 8ga running wire - SLP Headers/DP - HF Magnaflow Cat - Custom 2.5" Exhaust w/dump cutout - Magnaflow mufflers - 103AL@55 - Beldon Wires - MSD ignition - 1.8 Yella Terra roller rockers - 105# valve springs - custom push rods - locks - retainers - Meisure electric water pump - shift kit - false knock kit -
harofreak00 wrote:If you can't afford the fuel for a premium sucking car, you shouldn't be driving it. Sell it for an N/A.
Re: hmm, rocker time
Coming from a guy with rockers... Cam it now, don't waste your time/money with rockers.
MadMike
Post by MadMike »
well, heres the thing, i plan on having both in time anyway,
im kinda copying todds mod list cam and rockers to lighten up the valvetrain
and the rockers i can install over a weekend,
instead of an entire week-2weeks in the garage, (i dont have that kind of time)
You'd be installing rockers twice then. You can't have 1.9 rockers with a cam.
MadMike
Post by MadMike »
there 1.8 not 1.9 sir ;)
and as far as i know, 1.8 and stage 1 cam = solid build
1337ssei
Year and Trim: 1997 SSEI
Post by 1337ssei »
you can buy a special low lift cam that works with 1.8 and 1.9 rockers and provides the same like as an s1x or xp cams
Allmachtige
Year and Trim: 2009 G8 GT
Post by Allmachtige »
MadMike wrote:there 1.8 not 1.9 sir ;)
Try heads too.
I was young once and wanted to copy Todd as well, but that isn't how it works. Doing you're own thing builds a healthier sense of pride.
If you do rockers go 1.9's and you can get away with #90's. Rockers were a noticeable improvement on the 98.
As for "go cam or nothing", I won't jump on that statement yet because the work is not finished on my end, but it does have bearing....unless you blow a trans before a cam crossed your mind.
2009 G8 GT - White Hot
415/391
MadMike
Post by MadMike »
ok, well heres my plans for wat i have now,
wat im ordering and wat i want by the time im done
my current build is in my sig
im ordering 1.8.1 rockers and a few other goodies for the valvetrain
im also getting 105 valve springs, not 90. idk who said i was getting 90
after that, im not doing anything to the engine
im putting everything twards trans parts after that
then once the trans is built,
ill be getting stage 2 possibly 3 heads
and eventually the cam
my eventual goal is for 400whp, or 12.99 which ever comes first
MadMike
Post by MadMike »
either way, my main question was never answered!
is my parts list good?
Allmachtige
MadMike wrote:either way, my main question was never answered!
I'd recommend replacing the stock retainers.
415/391
MadMike
Post by MadMike »
check! got those to
final parts list is as follows
Viton® Valve Seals
Manley Performance Valvespring Retainers
INTENSE™ Rocker Installation Kit
(Including valve cover gaskets)
1994se
Post by 1994se »
valve cover gaskets, assembly lube, compression tester with an air hold, air compressor, torque wrench, oil change, coolant elbows (you have to take the alternator bracket off to get the rear VC off) and i think that's it.
http://www.thechicagogarage.org - Now Home of ILGPC
MadMike
Post by MadMike »
coolant elbows?
i dont have to break them or anything o.0
both upper and lower are new
but they like to break, and are cheap to replace.
MadMike
Post by MadMike »
hmm, looks like ill be getting those too i spose
willwren
Post by willwren »
Why 105's on 1.8's?
Why 1.8's instead of 1.9's?
Fuel injector o-rings, supercharger gasket, two yellow o-rings, coolant elbows, valve cover gaskets (grommets should be good), coolant, oil, filter, etc.
MadMike
Post by MadMike »
1.8 because i wanna do a cam in the next year also
105 because 90 seem a little weak for wat im planning to do
willwren
Post by willwren »
"Seem" and "are" are two different terms. 105's are a bit much for 1.8's IMO.
My advice is to 1.9 now and forget the cam, or cam now and forget the 1.8's.
MadMike
Post by MadMike »
105# still work with 1.8 tho correct?
cuz for when i get the cam as well,
i know ill need 105 to handle both cam and rockers
willwren
Post by willwren »
I think you're making a big mistake, and I'm going to strongly discourage you from that combination. Your choices from many logical standpoints should be 1.9 rockers OR a cam. If not ready to cam yet, save, and start getting ready. A new 2k cam install Techinfo is in the works right now, and is almost ready for release.
