The projectors are off a 05 Cadillac sts like so..
http://cgi.ebay.com/ebaymotors/2005-OEM ... ccessories
I got 2 housings with one ballast and HID bulb (one was missing
each housing had two projectors, one that was HID and one that is halogen but I couldn't tell the difference between the two. There is ALOT of cutting required. The projector shrouds in the sts were connected in a metal bracket so if you wanted to aim one you could aim both. So each housing had to be cut to make it look presentable and then I painted them after.
I do have two ballast and HID bulbs but one is whatever came with the housings (5k?) and one is from the set I bought a few years back (6k) so I will wait till I have a matching set, for now I just have 9005 halogens in.
Overall it was somewhat easy aiming them and such but the only thing that sucked was cutting the sts housing apart.
But worth it I love the look.
I will leave the taking them apart and how to put them together out because there are some other threads that have that.
Started with this
Inside you will find this
Most projectors come separately but if you choose to use these projectors, (I did because of cost), you will obviously need to cut the two housings apart, giving you this
At one point thought I lost my lenses...but...I found my fiancé and our friend playing with them...
I noticed that the HID lenses (low beam) are perfectly clear and the halogen (high beam) are slightly blurry. Hard to notice in pics.
Did some research and apparently the clearer the lens the sharper the cutoff.
The stock reflector just pops out with a little force and I mounted the projector directly to the back of housing
Here are both in, keep in mind all the space around the projector it hidden by the stock housing lens and black shroud inside it.
Painted part of turn signal reflector to match wheels and make it not so shiny.
My circuit, the Caddy lights came with HID bulb and Phillips HID ballast for lows and H11 halogen high beam bulb.
Low beam cutoff
High beam cutoff
Finished
Here are the pics on the car..
http://i15.photobucket.com/albums/a380/ ... G_0107.jpg
http://i15.photobucket.com/albums/a380/ ... G_0108.jpg
http://i15.photobucket.com/albums/a380/ ... G_0109.jpg
http://i15.photobucket.com/albums/a380/ ... G_0110.jpg
http://i15.photobucket.com/albums/a380/ ... G_0111.jpg
http://i15.photobucket.com/albums/a380/ ... G_0112.jpg
http://i15.photobucket.com/albums/a380/ ... G_0113.jpg
http://i15.photobucket.com/albums/a380/ ... G_0114.jpg
http://i15.photobucket.com/albums/a380/ ... G_0115.jpg
http://i15.photobucket.com/albums/a380/ ... G_0116.jpg
http://i15.photobucket.com/albums/a380/ ... G_0117.jpg
http://i15.photobucket.com/albums/a380/ ... G_0119.jpg
http://i15.photobucket.com/albums/a380/ ... G_0120.jpg
Member # 534.
