Tech II
Ragsdale
Year and Trim: 06
Tech II
Post by Ragsdale »
What type of things could I do to my 96 with a Tech II? My friend has access to like 6 of them and said he could hook me up with one for the night.
willwren
Re: Tech II
Post by willwren »
Alot of dangerous things if you don't have an FSM to go along with it, and quite a bit of knowledge/common sense.
petraman
2013 Audi A4 6MT
Location: ............ Granville, Ohio/Erie, PA *WCBF '08 SURVIVOR* *NEBF '07 SURVIVOR*
Re: Tech II
Post by petraman »
You can put the windows up and down and control the radio with mine :)
:lol:
RJGill84
Year and Trim: 2001 Pontiac Bonneville SE
Re: Tech II
Post by RJGill84 »
Peter - YOU have a Tech II?
"SLE without the ugly" - leather, climate control, sound, 3.05 gearing, 180* t-stat, tints. http://www.gillsystems.com
petraman
2013 Audi A4 6MT
Re: Tech II
Post by petraman »
lol, no I've just played around with Intense's Tech-II. It's fun.
Guest
Year and Trim: n/a
Re: Tech II
Post by Guest »
Few things:...but not all...
You can change settings in your Body Control Module....like change the delayed chime for your locks.
You can change the way your rack and pinion handles the road...Magna Steer...3 settings I believe
Or even have all your interior and exterior lights come on and stay on briefly when you unlock your car.
But as Bill said you need to know what your doing first so you don't screw thigs up bad.
Have someone experienced in Tech II help you for sure, don't even try to change things on your own.
