Data Link Communications
U1000, U1255 Class 2 Communication Malfunction
U1001, U1254 Loss of XXX Communications
U1300 Class 2 Data Link Low
U1301 Class 2 Data Link High
U1305 Class 2 Data Link Low or High
Lighting Systems
B2556 Interior Lamp Rheostat Circuit Range
B2627 Pass Compartment Dimming Circuit #2 Low
B2628 Pass Compartment Dimming Circuit #2 Low
B2641 Delayed Exterior Lighting Control Circuit Range
B2642 Delayed Exterior Lighting Control Circuit Low
B2643 Delayed Exterior Lighting Control Circuit High
B2646 Ambient Light Sensor Circuit Range
B2647 Ambient Light Sensor Circuit Low
B2648 Ambient Light Sensor Circuit High
B2657 Ignition Halo Lamp Output Circuit Malfunction
Entertainment
B1001 Option Configuration Error
B1780 Theft Lock Enabled
B2810 Steering Wheel Control Enertainment Circuit Malfunction
Cellular Communication
B2462 GPS Signal Error
B2476 Cellular Phone Select Service Switch Malfunction
U1500 Inter-Device Dedicated Bus Malfunction
Body Control System
B1000 ECU Malfunction
B1004 Keep Alive Memory (KEM)
B1007 EEPROM Write Error
B1009 EEPROM Checksum Error
B1010 Calibration ROM Checksum Error
B1390 Device Voltage Reference Input Circuit Malfunction
B1422 Device Power Moding Malfunction
Instrument Panel, Gauges, and Console
B2823 Trip Odometer Reset Switch Circuit Low
B2838 DIC Reset Switch Circuit Low
B2843 DIC English / Metric Switch Circuit Low
B3564 DIC Mode Switch Circuit Low
B3569 DIC Select Switch Circuit Low
Theft Deterrent
B2734 Coded Key Controller Memory Failure
B2947 Antenna Power Short to Ground
B2948 Antenna Power Short to Battery
B2955 Key Code Input Sort to Battery or Open
B2960 Invalid Coded Key Present
B3031 Key Decoder Device in Assembly Learn Mode
B3055 Key Not Present
Doors
B1562 Mirror Right Control Switch Circuit Low
B1567 Mirror Left Control Switch Circuit Low
B1572 Mirror Up Control Switch Circuit Low
B1577 Mirror Down Control Switch Circuit Low
B1582 LH Mirror Horizontal Position Sensor Circuit Low
B1583 LH Mirror Horizontal Position Sensor Circuit High
B1592 LH Mirror Vertical Position Sensor Circuit Low
B1593 LH Mirror Vertical Position Sensor Circuit High
B1612 RH Mirror Horizontal Position Sensor Circuit Low
B1613 RH Mirror Horizontal Position Sensor Circuit High
B1622 RH Mirror Vertical Position Sensor Circuit Low
B1623 RH Mirror Vertical Position Sensor Circuit High
B3142 LF Unlock Switch Circuit Low
B3147 Passenger Unlock Switch Circuit Low
B3152 LF Lock Switch Circuit Low
B3157 Passenger Lock Switch Circuit Low
B3172 RF Window Up Switch Circuit Low
B3177 RF Window Down Switch Circuit Low
B3182 LR Window Up Switch Circuit Low
B3187 LR Window Down Switch Circuit Low
B3192 RR Window Up Switch Circuit Low
B3197 RR Window Down Switch Circuit Low
B3377 LF Window Up Switch Circuit Low
B3382 LF Window Down Switch Circuit Low
B3387 RF Window Up Switch Circuit Low
B3392 RF Window Down Switch Circuit Low
B3397 LR Window Up Switch Circuit Low
B3452 LR Window Down Switch Circuit Low
B3457 RR Window Up Switch Circuit Low
B3462 RR Window Down Switch Circuit Low
B3467 LF Window Express Down Circuit Low
B3472 RF Window Express Down Circuit Low
B3527 Window Lockout Switch Circuit Low
U1161 Loss of PDM Serial Data
U1162 Loss of LRDM Serial Data
U1163 Loss of RRDM Serial Data
U1170 Loss of Driver Door Switch Assembly Serial Data
Seats
B1735 Driver Seat Front Up Switch Circuit Malfunction
B1740 Driver Seat Front Down Switch Circuit Malfunction
B1745 Driver Seat Rear Up Switch Circuit Malfunction
B1750 Driver Seat Rear Down Switch Circuit Malfunction
B1755 Driver Seat Assembly Forward Switch Circuit Malfunction
B1760 Driver Seat Assembly Rearward Switch Circuit Malfunction
B1815 Driver Recline Forward Switch Circuit Malfunction
B1820 Driver Recline Rearward Switch Circuit Malfunction
B1825 Driver Recline Sensor Circuit Malfunction
B1826 Driver Recline Sensor Circuit Performance
B1830 Driver Lumbar Forward Switch Circuit Malfunction
B1835 Driver Lumbar Rearward Switch Circuit Malfunction
B1840 Driver Lumbar Up Switch Circuit Malfunction
B1845 Driver Lumbar Down Switch Circuit Malfunction
B1850 Driver Lumbar Horizontal Sensor Circuit Malfunction
B1851 LF Lumbar Horizontal Sensor Circuit Performance
B1860 Driver Lumbar Vertical Sensor Circuit Performance
B2355 Driver Front Vertical Sensor Malfunction
B2356 Driver Front Vertical Sensor Performance
B2365 Driver Rear Vertical Sensor Malfunction
B2366 Driver Rear Vertical Sensor Performance
B2375 Driver Seat Assembly Horizontal Sensor Circuit Malfunction
B2376 Driver Seat Horizontal Sensor Performance
B2757 Driver Memory 1 Select Switch Circuit Low
B2762 Driver Memory 2 Select Switch Circuit Low
B2772 Driver Memory Exit Switch Circuit Low
2000 - 2005 SSEi, SLE, SE Body and Acessory codes (non GXP)
Moderator: Gearheads
- Year and Trim: .
Last edited by myfirstbonnie on Tue Jan 27, 2009 2:45 pm, edited 2 times in total.
