Armstrong steering (no more power!!)
rockit-man
Year and Trim: 95 Bonneville SLE
Post by rockit-man »
Lost my power seering today, and the fluid is right up. I had no moaning or humming, everything seemed fine untill... nothing. I have a spare power steering pump from my 94 se, but I'm not sure if a series I pump will Fit on my series II engine. The pump isnt even in the same place, its way lower on my 95. Anything else it may be besides the pump? Hope someone can help. Thanks in advance.
Series II, Leather, K&N with a rice pipe, drilled 180' t-stat, aluminum LIM gasket, tinted, custom grill, michlin hydro edge rubber, 200 watt JVC deck, 12" orion with an 800 watt exterminator pushin.
rockit-man
Re: Armstrong steering (no more power!!)
And while Im at it, how do I change that stupid serpentine belt?
tan96ssei
Year and Trim: 1996 SSEi
Post by tan96ssei »
well i had a similar problem at low idle my steering was like turning a tank. once i gave it gas the steering loosened up. i also was told when i had my problem it is very uncommon for the actual rack assembly to go bad. the common cure to your ailment would be the pump. im 85% sure on that. as for the serpentine belt check this link http://www.pontiacbonnevilleclub.com/fo ... =53&t=2652 this should tell you everything you need to get the show on the road
Aerospace Propulsion Technician USAF
Airman First Class,
.:Michael Lyons:.
parts available on 96 see thread viewtopic.php?f=27&t=15185
