How to: 2000+ radio light fix tutorial (45pics)
***edited with new photo hosting 7-10-17 because Photobucket sucks***
I finally had a chance to redo my original tutorial of the radio light fix. The original tutorial gave you the general idea of how to fix it, but it didn't really touch on the display bulbs, which are the most common problem. I'm going to lock that thread and start over here.
Your first step should be to get the new bulbs you need. As far as I know, the display bulbs are available exclusively from www.CorvetteRadios.com for $23 shipped for the 3 bulbs. They look VERY similar to a 2174 bulb, but I will be able to confirm that later this week. If this is true, we will be able to get the bulbs for basically the spare change in your pocket, not $23.
Here are the bulbs I received from CorvetteRadios.com
Here are the other bulbs you will need. I found them at RadioShack for $1.79 for a 2-pack. 12V Microlamps (2-Pack) 272-1092
***thanks to hawkjet for his supplied pictures***
To get the radio out, you need to take apart the dashboard. It may look ominous, but it really doesn't take long (the second time you do it, you can do it in 15 to 20 mins.). First remove the fascia from around the instrument panel and radio. There are two plastic rivets going up into the fascia above the instrument cluster. Press the center of the rivets upward (pics 1 & 2) and then carefully pry the rivets out (pic 3).
Pry the trim ring off the ignition switch (pic 4) notice I put electrical tape around the screwdriver blade to avoid marring the trim. Then pull out the 'cubby hole' on the left of the wheel (pic 5). Tilt the wheel all the way down and pull the panel off the dash (pic 6).
Reach behind the right side and disconnect the connector(pic7). Carefully tweek the panel to get it around the wheel and out of the way. It will help to have the wheel tilted down as far as it can go.
The actual stereo pulls straight out after releasing the retaining clips.
I am going to show you how to do this on both "cassette" and "non-cassette" stereos. There is a simple difference, if you have the non-cassette stereo, you have it easy. Find a clean workspace and grab some tools.
You'll need:
25-30W Soldering Iron & maybe some solder
Small flat-blade screwdriver
Small pliers and/or needlenose
First, turn the stereo upside down and remove the bottom plate. I used a small screwdriver to pry it up gently, but you might need to use some force since it is possibly held in place with a adhesive.
After removing the bottom plate, you will see some small wiring and connectors.
This part of the tutorial is for those with a cassette deck.
Turn the stereo upside down and remove the bottom plate the same way as above.
Once you have it open, you will see the cassette deck is in the way of removing the wires for the faceplate.
Remove the 4 small screws that hold the cassette deck in place and pull it out of the way.
You can even fully disconnect it if you want to.
That is the only difference between the two types of stereos, back to originally scheduled program.
Pull up on the connectors, VERY CAREFULLY, you do NOT want to damage these, you'll be kicking yourself.
Remove both connectors.
Use a small screwdriver to release the 8 tabs that hold the faceplate onto the body.
Gently remove the faceplate from the stereo, fishing the wires out of their holes, being sure not to knick any of the wires on the way out.
Now you have the faceplate removed from the stereo.
Now, remove the Volume and Tune knobs from their shafts, they pull straight off with some force. (No tools needed)
There are 5 small screws that hold the circuit board to the faceplate. I believe they have a 3mm head, and I didn't have a small enough socket, so I just used my pliers.
Remove the circuit board from the faceplate. Be sure to hold the faceplate button side down, or the buttons will fall out of their holes and you will have a mess on your hands. Set the faceplate to the side.
In case you do have any buttons falling out of place, here is how everything goes back together.
Now here we have the circuit board with all the bulbs, LED & Incandescent. I circled all the incandescent bulbs. If you are in here replacing 1, I suggest you replace all of them. They are bound to burn out sooner than later.
On this particular stereo, it only had a single working incandescent bulb on the entire board.
Now, remove the old burnt out bulbs by melting the solder that holds the bulbs in and pull them straight out.
Insert the new bulbs and solder them in, leaving the glass base about 1-2mm away from the circuit board and test your work.
Clip the ends of the wires off the back.
To get at the display bulbs, you need to remove the LCD display. Turn the board upside down and you will see 6 tabs.
These need to be bent straight so you can remove the display.
Pull the display straight off and set aside. Be sure not to get anything inside the display, store it face-up.
Since all the bulbs are on 1 circuit, you can test the display bulbs to see what ones are working, but it doesn't really matter, replace them all.
Solder the display bulbs in the same way you did the smaller ones, but be sure you leave a little more wires exposed, and then bent the wires at a 90* angle like they were before.
Test your work again.
Insert the LCD display back into place.
Be sure to bent the tabs back to hold the display in place.
Now is the time to clean the LCD display from all the fingerprints you put on it before you put it back into the faceplate.
Place the circuit board back into the faceplate, and screw it down with the 5 small screws.
Push the volume and tune knobs back onto their appropriate shafts.
Fish the wires/connectors through their own holes in the body and snap the faceplate back into place.
Push the wires/connectors back into place.
If you have a cassette deck, now would be the time to re-install that. Finish up the job by snapping the bottom cover back into place.
Put the stereo back into the car and admire your work!
bonnevillain
Re: How to: 2000+ radio light fix tutorial (45pics)
Post by bonnevillain »
i did this a few weeks ago, and its every bit as much of a pain as it looks. I wish i would have waited for some of this! took me a while to figure everything out, and once i did, it was difficult because i had no tools that small. i used a needle nose pliers to unscrew most of the screws. why does your radio say locked?
This is a spare radio I bought off ebay, I was just testing to make sure I actually fixed it.
RJGill84
Year and Trim: 2001 Pontiac Bonneville SE
Post by RJGill84 »
Just to ensure they didn't burn out quickly again - couldn't you replace the incandescents with LEDs?
Nice write up - I'll be doing this in the near future. My entire radio is basically burnt out :(
"SLE without the ugly" - leather, climate control, sound, 3.05 gearing, 180* t-stat, tints. http://www.gillsystems.com
maybe on the bottom row, yes. But I'm not sure how you would have an LED fit under the LCD display board, the incandescent bulbs sit in there at 90*.
RJGill84
Post by RJGill84 »
I'm not sure why that would be an issue. The wires going into the LEDs would be just as long as the incandescents you used, so you could easily bend them to 90*.
http://www.superbrightleds.com/specs/W15120_specs.htm are the ones I'm thinking of using. These particular ones output light at 120 degrees, so they should light up the display fine. At $1.05/ea you can't beat em.
The light from the bulb would be shining straight down, only the bottom of the display would be lit. Also, you would need to wire in a resistor. Go ahead and try it, I'm curious.
RJGill84
Post by RJGill84 »
harofreak00 wrote:The light from the bulb would be shining straight down, only the bottom of the display would be lit.
You're probably right about the resistor - I'll have to figure that out. But the light from these particular LEDs is a full 120 degrees, so the display should be lit up just as good.
This is my reasoning of why the LED wouldn't work. 120* is great, but the incandescent bulbs are 360*.
RJGill84
Post by RJGill84 »
The way you have it illustrated wouldn't work, but I wasn't planning on doing it that way haha :booty:
With the incandescents, you're wasting 180* of light...and the 40 degrees lost with using an LED is not really a big deal. But THIS is how I would mount them...
I guess that would work, but just to play the devil's advocate, you might be seeing 3 very distinct lit areas on the display. The hardest part is probably going to be getting the resistor in there. Could you find a 12v LED with a 120* pattern?
FYI, the incandescent bulbs from CorvetteRadios are rated at 40,000 life hrs, that should outlast most of our cars.
bonnevillain
i see 3 light patterns even with the incandescents. it's more noticeable if you take a picture of the radio and look at it afterwards. i can see them in your picture too.
RJGill84
Post by RJGill84 »
Yea - I was thinking that. They make frosted (diffused) LEDs. I noticed a bit of that in your pictures as well, and then realized that the stock bulbs are frosted, and the ones from CorvetteRadios.com are not.
I imagine I could find a frosted 12 volt 120* LED somewhere...
EDIT: Ack! Bonnevillain, we posted @ the same time- 3:14...lol
bonnevillain
you can always try sanding them a bit. it helped the LEDs i had in my footwells. I sanded off the tip that focused the light, and it gave them a nice wide pattern.
RJGill84
Post by RJGill84 »
Those would be ideal! Didn't see those. All thats left is the resistor application.
I'm also looking at LED light strips. Some of them come on rolls, and you can cut them in pieces. The xFLS-NW30 is a 12v light strip - http://www.superbrightleds.com/specs/FLS.htm
I could just solder it to one point, rather than 3, and mount the strip in there. These are surface mount LEDs, so they're naturally pointing outward.
Interesting idea, but I think I will end up going with the LEDs you suggested.
DR_Gonzo
Year and Trim: 2003 SSEi
Post by DR_Gonzo »
Just curious...do you have the technical stats for the bulbs used in these radios? The price that corvetteradios charges seems pretty high. I'm guessing you could find them at mouser.com for a few cents a piece.
2003 Bonneville SSEi Granite Metalic
I agree the price is high. I don't have the tech data from the bulbs. They are not labeled and I'm not sure of the specs.
DR_Gonzo
Post by DR_Gonzo »
When testing those bulbs, are you feeding them 12V or something less? Also, if you had to guess...about how tall (long?) is the bulb with the base?
Yes, a 12 power source.
The bulbs are 5x11mm.
Like I said in the original post, 2174 bulbs are the closest I found, but I'm not sure if they are the right brightness level.
