willwren wrote:Thomas, you're talking about the one under the harmonic balancer?
The one we replaced on Celin's car at WCBF?
Crappy design. In comparison to the H-body TA mount anyway. I have one of those GP mounts at home, I may just have to look at that sucker. The trick is getting all 4 fasteners/studs properly located before the poly pour.
Yes, yes and yes...
The other thing is I'd like it 3/8" shorter because I have an IC and the engine sits so high with the new mounts that the SC touches the hood and its rubbing a hole in my hood.
I also need to make one for the other side.. the "trans Mount" ZZP sells them for $79.00 and advertise that you will feel much more vibration.
I also have a few spares on the trans mount too.
Bill.. Wren, I can make a jig to hold the position of the mount during pour and setup of the poly.
I was wondering how easy or difficult it will be to get all the old rubber off the mount? I was thinking to just burn it off with a torch..
