For months now when I apply the brake pedal the car feels like it is lunging - like the brake rotors are warped. This past weekend I replaced the front rotors and front brake shoes. One rotor was damaged more than the other but both had deep gouges in them at concentric circles around the disk. The pads were also worn down. I lubed the pins in the calipers and checked to make sure they moved smoothly. I thought for sure the damaged rotors were the reason I was experiencing the lunging sensation.
The brakes grab a lot quicker but I have the same lunging sensation when braking. Any thoughts. Could brake ABS sensor be the issue?
Thanks...Milty.
Braking - lunging sensation
Re: Braking - lunging sensation
Anyone have thoughts on this problem?
- harofreak00
You did install new pads with your new rotors, correct?
- TheJMFC
- Posts like an L36
- Year and Trim: '01 Saturn SL1,
'07 Grand Caravan SE - Location: Jenison, MI
Bad drums in the rear could also cause that, if I'm not mistaken.
ABS, I'd think you would hear/feel it kicking in.
I'm Jon. I'm completely stock, no mods.
2001 Saturn SL1: "Nameless" Stock. Manual. 243,000 miles. Yes, original engine. No, doesn't smoke.
2007 Dodge Grand Caravan SE: "The Van" Stock. A miserable necessity of adult life. 165,000 miles.
Sold, probably dead: 1993 Bonneville SSE "The Work Beater" Stock. Tried to kill me a few times. Failed.
Sold: 1996 Buick LeSabre Limited, "The family car" Custom CAI, F41 Sways.
Sold/dead, but not forgotten: 1989 Bonneville LE "Bonnie, the Sport Utility Car" STB from '92-'99 Bonnie, Delco (Type II) Ignition system
I replaced the front pads but have not checked the rear drums. It seems like the lunging is from the frontend but I'm not positive.
- 93RedSled-SSE
- Retired Gearhead
- Year and Trim: 1993 SSE (NA)
If your definition of lunging is that sensation when the rotors are warped, you will feel it (pulsing sort of jiggle) in the steering wheel at braking more than anywhere (front rotors warped). If that is the case, and you have replaced the front rotors and pads... and you STILL feel it in the steering wheel, it could be an issue with a front tire/wheel. In this situation, I would rotate the tires, front to back and see if the problem moves or goes away.. telling you it is a wheel or tire that you moved to the back.
So, back to your definition of "lunging;" if it more of a pulling, maybe due to a brake grabbing, you need to figure out which wheel it is; does it pull to one side or the other like the steering wheel would do? If so, you could have a problem with a sticky caliper. If it is a back brake simply locking up, your back brake shoes may need adjustment or could be due to moisture in the drums. Just throwing all that fodder out for thought.
Thanks for all the ideas - I will start by rotating tires and look at the back brakes at that time. Car does not pull to one side when braking. Calipers are fairly new.
