Rocker arm ratio from factory -hmmmm
olblueeyesbonne
Year and Trim: 99 SSEi
01 SLE
02 GTP40th
02 SSEi
06 GP GT
Post by olblueeyesbonne »
Was reading on CGP how some GTP's have been found to have as much of a ration as 1.8 on their original rocker arms and I'm wondering if mine might possibly be that high, thus helping to understand how my car can pull so well up top, and overall.
A few people have been wondering how my car is capable of times and speeds that have mainly been acheived by cars with high ratio rockers or one or two other mods, none of which I had on my car at the time of the 13.xxx runs.
How does one go about checking the ratio of their rockers? I am probably going to put the HS 1.9's next week and would like to check the stock rockers if I can before I get rid of them.
Last edited by olblueeyesbonne on Thu Oct 02, 2008 8:51 pm, edited 1 time in total.
DHP Powrtuner & Tech 2
1998 GTP Coupe
1999 SSEi 70k miles
2001 SLE
2002 GTP 40th Anniv Ed Coupe
PDXGTP
Year and Trim: 1998 Pontiac Grand Prix GTP
Re: Rocker arm ratio from factory -hmmmm
Post by PDXGTP »
So I'd like to say don't get rid of your stock rockers, valve springs or pushrods. Also keep the rocker ped with the set. You never know when your going to need them. Try to keep them all oiled sloppy and wet, in a ziplock bag.
Iknow that the ratio is determined by how far the pushrod seat is to the trunion. The closer to the trunion, the higher the ratio, valve opens sooner and stays open longer.
Are you changing your springs?
Sorry, didn't look at your sig before posting .. your motor.
Best 60' = 1.716
Best ET = 12.186
Best MPH = 112.98
Dirthead Racing
Year and Trim: 97 ssei
12.67@103
Post by Dirthead Racing »
Times after 1.9RR's go on should be a good indicator. I suspect you have 1.9 mod'd rockers and don't know it because they don't look any different than stock ones. That would justify your 98mph trap speed.
olblueeyesbonne
01 SLE
02 GTP40th
02 SSEi
06 GP GT
Dirthead Racing wrote:Times after 1.9RR's go on should be a good indicator. I suspect you have 1.9 mod'd rockers and don't know it because they don't look any different than stock ones. That would justify your 98mph trap speed.
How about the 99.1x-99.67 mph runs? :wink: :???:
That is a good point on the post RR install times, but I've got the ported SC, 3.3", Ceramic coated P-log, and fine tune all going on between now and Oct. 18 and/or 19 when I head to the track for the last time this year.
I've also got a pair of slicks coming again (just waiting for the QTP owner to clarify he's ok with me running them again while he's @ college in IL).
1998 GTP Coupe
1999 SSEi 70k miles
2001 SLE
agrazela
Year and Trim: 04 Lesabre, Stock
98 Lesabre, Retired
Post by agrazela »
ol' blue,
After you take them off, post pics of the pushrod sockets on your "stock" rockers and the "stock" pedestals and we'll see if they are modified stockers.
Bone Stock
Retired
Foghorn
Year and Trim: 1997 SSEi 40th Anniversary
13.07 @ 106.5
Post by Foghorn »
1.8 on stock rockers is myth. There was some dispute at to whether later models had 1.66:1 versus 1.60:1. This may be explained more by production tolerances and measuring techniques than anything else.
There's nothing unusual about your trap speeds. When I had similar mods I did similar times to yours with even slightly higher trap speeds.
Cheers,
2003 SSEi
Year and Trim: 2003 SSEi.
LOTS of Mods
Post by 2003 SSEi »
Foghorn wrote:1.8 on stock rockers is myth. There was some dispute at to whether later models had 1.66:1 versus 1.60:1. This may be explained more by production tolerances and measuring techniques than anything else.
Cheers,
agreed with Paul. I have Trapped 102mph in my car with out a bolt being touched on the motor.
