stability system
- pete25
- Year and Trim: 2003 Pontiac Bonneville SSEi
stability system
My 2003 SSEi has now come up with the warning "Service Stability System" and the ABS Brake And Traction lights come on inside the instrument panel. And the traction control turns off on the button to engage/disengage it. It's happened three times but spread out over like a week or two. Is something to be worried about?
- Archon
Re: stability system
With that warning, along with the ABS and traction control warnings, it is likely a failing wheel speed sensor in one of the wheel hubs. Your Stabilitrak system, abs, and traction control are disabled when it happens. It will not cause any damage.
