Traction Control doesn't work
Yoshicoby
Year and Trim: 1998 Bonneville SLE
Post by Yoshicoby »
Okay.. I think I've found a new project for the ride. I don't think my traction control has worked since I've owned my Bonneville. It makes a sound whenever I lose traction and continues for a few seconds after I regain traction. This isn't normal is it? And it seems like it always comes from the left front? Any suggestions? Thanks!
(hopefully simple)
bonnevillain
Re: Traction Control doesn't work
Post by bonnevillain »
that's normal... that sound is made when the Traction control IS working. sounds kinda like ABS right?
Yoshicoby
Post by Yoshicoby »
Yeah I guess so. but alright, I thought something might have been wrong with it. Cool, thanks!
nicklikesmilk
Year and Trim: 98 Oldsmobile Intrigue
Post by nicklikesmilk »
mine makes noise when it works. i think it's just cuz our cars are around 10 or more years old, so they didn't master quite TC yet.
if it's not working, your dash should have a light that says "traction off" illuminated.
1993 Park Avenue
200k, well-optioned, and running strong
Yoshicoby
Post by Yoshicoby »
No, that light isn't on. Thanks for your reply though. Good info to know!
94SCparkavenue
Year and Trim: 1994 Buick Park AVenue
Post by 94SCparkavenue »
i have a tc button but when i push it the light doesnt come on for tc off. what could cause that ?
teleplayer
Year and Trim: 1992 SSEI
Post by teleplayer »
In my experience, the traction control is fairly useless. If you take off on a wet street, it is distracting when it kicks in - I'd be happier to just let the wheel slip and cope with it. And it never helped me if I was stuck on snow or ice. It's too bad you can't easily shut if off and have it stay off. Best solution is limited slip in the transmission, but it's not worth it for me to pursue that on a 16 year old car.
1992 SSEI 170k miles
willwren
Post by willwren »
I have no TC on either car any more. I don't like how the system works, it's too expensive to repair either of them, and I'd rather KNOW how the car wil respond rather than get used to TC saving my :booty: then have it fail at a very unpredictable moment.
SingsCountry1967
Location: North of Buffalo, NY __Been there, done that, got the t-shirts
Post by SingsCountry1967 »
94SCparkavenue wrote:i have a tc button but when i push it the light doesnt come on for tc off. what could cause that ?
...blown dash bulb? or someone disabled it prior to you?
Last edited by SingsCountry1967 on Fri Sep 19, 2008 12:14 pm, edited 1 time in total.
'00 SLE Maple Red -"Crisis Management" - (125k)- Customized in Silver... Driven with Excitement. RIP 2013 the Crisis is Over
Plugs/wires @ 51k, UIM/LIM gasket @ 59k. Ignition Ctrl Modual @ 109k '04 Monte Carlo SS - "Dream Chaser" - 3.8L SII - (82k miles)...Purchased 8-7-08...Still Driving!
94SCparkavenue
how do i disable it ?
willwren
Post by willwren »
Either disconnect a wheel speed sensor or two, or disconnect the PMV assembly (large round black twist-lock connector under your airbox). FYI, this will ALSO disable ABS.
sandrock
Post by sandrock »
For 1996 and up models, traction control is tied to the PCM...so one could still have ABS enabled if traction control was deactivated. However, the PCM will have to be programmed with a DTC delete that is specific to the TC.
Just throwing that out there :wink:
