Noise when turning left.
Pair of SSEI
Year and Trim: 1997 SSEI 40th
Post by Pair of SSEI »
I'm getting a low growl when turning left, even when just changing lanes. Front end has been aligned but noise continues. Any ideals were to start? Wheel bearing ?
1997 SSEI 3.8 L67 149,000 miles Moonroof, Polished Gen V w/L32 intake, 3.5 mod. Pulley, SD Headers, Intense Stage 1 tune, MagnaFlow Cat 94109, Catco catback, Autolite 103s, 180 stat, Intense FWI, 1995 OEM trans cooler, Cleared corners. KYB Excel G struts and shocks.
2006 Malibu SS 3.9 60 degree V6, Variable Valve, Tap shift Trans, 100,000 miles Bone stock
SOLD - 1992 SSEI FWI PEM Catco Cat NGK TR55 180 stat Original owner 209,000 miles Original Engine and Trans - Still strong when she left
95naSTA
Re: Noise when turning left.
Post by 95naSTA »
If I remember right, whenever I had wheel bearing issues on this chassis, it would stop making noise when I got on the brakes.
Either way, I would jack up each corner and check for wheel play.
