I tried switchback LEDs, both random Amazon brand and Diode Dynamics, and they are always yellow. Never white like they should be when on as parking lights. I am talking about the turn signal bulbs in the headlights by the grill. They are 2057 bulbs.
I've done some multimetering and some stand-alone voltage regulating.
On as parking lights:
Pin A has 10v
Pin B has 12.5+ (running system voltage)
When turn signal is on:
Pin A cycles between 12.5+ and 2 volts
Pin B has 12.5+
With the voltage regulator and the LED in hand, the only way to get the white light is when only pin B has voltage. If both pins have voltage, it is yellow. Even when they both have just 10 volts. Seems like I need to get down below 7 volts before nothing lights up.
So to make the LED switchback like it should, I would have to block the voltage above 7 volts to pin A while the parking or headlights are on, but allow voltage to pin A when the turn signal is on.
How would I accomplish that?
WHITE WHINE - 1992 SSE Supercharged 236.26 ci (.040 Over) 15.090 at 90.2 MPH on old engine w/ slipping trans & melted O2 sensor - Gen 3 M62 and matching TB, Gen 2 Pully, Zillamotorsports Ported LIM, YT 1.72 Roller Rockers, SII FPR & Injectors, Hypertech Thermomaster chip w/ 160 Thermo, TransGo Shift Kit, Infinity/Pioneer Speakers & a 10" Alpine Type R Sub, all the watts, 140 amp Alternator, Ricepipe CAI w/ heatshield, Pilot Angel Eye Foglights, Clear Corners, '02 17" Chrome Bent 5's, Magnaflow F-Body Muffler and Hi-flo Cat, Ceramic Coated Ported Exhaust Manifolds, Fan Override, Monroe Reflex struts, red calipers 2009 G8 GT - Sport Red Metallic, loaded, SOLO Axlebacks, Rotofab Intake, Tuned, autodim mirror, removed intake manifold cover, HSV GTS triple gauge pod, two tone red-hot shifter and HSV SuperSport steering wheel, GXP rear sway bar and diffuser, 3.45 diff and various Camaro suspension bits, LED Taillights
I think the parking lamp power and turn signal power comes from different paths. I think if I snip the parking lamp power circuit (pin A), the LED will work as intended. I think that will also set off the bulb monitor. I think I can fix that by putting in a resistor to ground on the snipped circuit. I think maybe putting a resistor inline with that circuit instead could also work. I think I need to look at my FSM.
I've just quickly cycled the power switch for the light I have them on. I have switch backs in the fogs on the Caddy. A quick cycling of the fog light switch, switches them.
Retired Bonneville Owner and former GM Tech: 2004 Pontiac Bonneville GXP: Black/Ebony *SOLD*
Daily Drivers: 2019 Chrysler Pacifica Limited: Mommy's new RGC 2015 Chrysler Town & Country Limited Platinum: Kids new RGC 2011 Camaro SS 2009 Pontiac G8 GT: L76, Sport Red Metallic 2004 GMC Sierra 2500HD: Victory Red - 8.1L Big Block and Allison 2003 Chevrolet Suburban 2500: Doeskin Tan - 8.1L Big Block... RIP 1999 Chevrolet Suburban: Sunset Gold Metallic - RIP
