12v Outlet - Where is it?
MrPerro187
- LE Member
- Year and Trim: 2004 Pontiac Bonneville SE
I have a 2004 Pontiac Bonneville SE. I have looked everywhere in my car and I cannot find the 12v outlet for the life of me. Can someone point me in the right direction of it? All I see is the cigarette lighter port towards the bottom, but that's it. If that is where it is supposed to be, can I turn it into a 12v port? Thanks in advance.
- J Wikoff
- Year and Trim: 1992 SSE
Re: 12v Outlet - Where is it?
They are one in the same. Take the cigarette lighter out and plug you phone charger in.
MrPerro187
- LE Member
Okay, thanks a lot. I actually tried to plug in a 12v charger in there (mainly for my GPS), but it didn't work. I'll probably have to try again, but if it doesn't work, do I have to check a fuse somewhere?
- J Wikoff
Yeah the fuse might be blown. I don't know where the fuses are on that generation though.
- nos4blood70
- Year and Trim: 2003 SLE
Fuse for the 12V is in the under the hood fuse block.
