No power supply to my windows..
Mitchell77
- Year and Trim: 1998 se bonneville
So I've tried testing the window switch with test light and its getting no power I've also tried testing just the wires and there getting no power, I've also tested the fuse box relay area and on the passenger side fuse box and that's there is going to there but I'm not getting power to the window.... anyone ever come across these misfortunes? Or kno how to Dress it.
- J Wikoff
- Year and Trim: 1992 SSE
Re: No power supply to my windows..
Maybe the wires running into the door through the grommet between the A pillar and door are broken from years of bending as the door opens and closes.
Mitchell77
But shouldn't I be able to manually reach and use the backs ones there not workin at all.. none of my windows smh
- J Wikoff
I am not positive, but all the power for the windows might run through the driver switch. Other than that, I'd be looking for the window fuse.
- harofreak00
Probably a bad master window switch.
Power Windows Circuit Description
A permanent magnet motor operates each power window. Each motor raises or lowers the glass when voltage is supplied. The direction the motor turns depends on the polarity of the supply voltage.
The LH front power window switch controls the following components:
All of the motors
Power window control module
Each window switch controls only 1 motor.
LH Front Power Window Switch Operation
Battery voltage is applied to the POWER WDO/SUNROOF RELAY coil in the IP junction block from CKT 43 under the following conditions:
The ignition switch is in the ACCY position.
The ignition switch is in the RUN position.
During the retaining accessory power (RAP).
The relay is permanently grounded on the coil side. Battery voltage is applied to the LH front power window switch under the following conditions:
The coil is energized.
The switch is closed.
Battery voltage is applied to the window motor when any UP switch in the LH front power window switch not associated with the express down is operated. The window motor is grounded through the DOWN contact of the LH front power window switch. The motor runs in order to drive the window up. Battery voltage is applied to the window motor in the opposite direction when any DOWN switch in the LH front power window switch is operated. The window motor is grounded through the UP contact in the LH front power window switch. The motor runs in order to drive the window down.
EXPRESS DOWN Window Operation
The EXPRESS DOWN window function is a convenience feature that allows you to fully open the LH front window by holding the LH front power window switch down for more than 0.3 seconds then releasing. You may stop the window at any position by momentarily pressing the UP or DOWN switch.
The power window control module receives the power at terminal A under the following conditions:
When the LH front window switch is held down for more than 0.3 seconds and released, the timer and control unit detects this at the down input terminal. The relay control switch closes, completing the coil circuit through the UP switch in the LH front power window switch to ground. The relay contacts close. The LH front power window motor receives battery voltage. Terminal A of the motor is grounded through the left front power window switch UP contact. When the window is fully down, the motor stall current is detected at the current sense input of the timer and control unit. The relay control switch opens, de-energizing the coil and disconnecting the power to the motor. The motor also stops 10-30 seconds after the DOWN switch is pushed.
The timer and control unit detects at the input terminal if the left front power window switch is pushed while operating in the EXPRESS DOWN mode, opening the relay control switch. Terminal A of the motor is also now not grounded through the LH front power window switch. The window stops moving down. If the power input at terminal A of the express down module is lost, the power window still operates. However, the power window operates without the express down feature.
Battery voltage is applied to the window switches and the window lockout switch through the POWER WDO/SUNROOF RELAY under the following conditions:
When the UP switch in the window switch is operated, battery voltage is applied to the window motor. The motor is grounded through the DOWN contacts in the following components:
Window switch
The motor runs in order to drive the window up. When the DOWN switch in the window switch is operated, battery voltage is applied to the window motor in the opposite direction. The motor is grounded through the UP contacts in the following components:
Window switch
Each motor is protected by an electronic circuit breaker. The circuit breaker opens the circuit under the following conditions:
A window switch is held too long with the window obstructed.
A window switch is held too long after the window is fully up or down.
The circuit breakers have positive temperature coefficients. The circuit breakers reset automatically when voltage is removed from the motors.
- Attachments
[The extension pdf has been deactivated and can no longer be displayed.]
Mitchell77
Where is the window control module located ? Is it on the driver door inside the door panel?harofreak00 wrote:Probably a bad master window switch.
All of the motors
Window switch
Window switch
- harofreak00
(1) S510
(2) P500
(3) S505
(4) S506
(5) C210
(6) C212
(7) S504
(8) S503
(9) S502
(10) Traction Control Switch( if Equipped)
(11) S501
(12) S500
(13) LH Front Power Window Motor (RH Similar)
(14) Power Window Control Module
(15) C502 (LH) C603 (RH)
(16) C503 (LH) C602 (RH)
(17) C501 (LH) C601 (RH)
(18) LH Front Door Lock Actuator C2 (RH Similar)
(19) LH Front Door Lock Actuator C1 (RH Similar)
Mitchell77
So when I checked the harness to the window control module it had no power... but my circuit breaker fuse is showing 12v. Would this jus be a bad harness?
Mitchell77
So this morning my master switch decided it wants to work properly...
Only thing different is I have put my radii fuse back in ... I don't kno if they share a circuit but it may be possible.
Thanks for ur time guys..
- harofreak00
If you look at the schematic for the right side window motors you'll see the radio fuse is the trigger wire for the power window relay. Was this the problem the entire time?
Mitchell77
Yes sir lolharofreak00 wrote:If you look at the schematic for the right side window motors you'll see the radio fuse is the trigger wire for the power window relay. Was this the problem the entire time?
I put the fuse in and click back to operation
