Need to replace the back 4 subframe bushings. Frame is still good. Trying to get the correct parts
. Anyone have a link?
subframe bushings 1997
- Pair of SSEI
- SSEi Member
- Year and Trim: 1997 SSEI 40th
1997 SSEI 3.8 L67 149,000 miles Moonroof, Polished Gen V w/L32 intake, 3.5 mod. Pulley, SD Headers, Intense Stage 1 tune, MagnaFlow Cat 94109, Catco catback, Autolite 103s, 180 stat, Intense FWI, 1995 OEM trans cooler, Cleared corners. KYB Excel G struts and shocks.
2006 Malibu SS 3.9 60 degree V6, Variable Valve, Tap shift Trans, 100,000 miles Bone stock
SOLD - 1992 SSEI FWI PEM Catco Cat NGK TR55 180 stat Original owner 209,000 miles Original Engine and Trans - Still strong when she left
- Pair of SSEI
- SSEi Member
Re: subframe bushings 1997
Ordered parts, here we go.
- 95naSTA
- Year and Trim: 95 SLE
Did you go aftermarket or find NOS?
- Pair of SSEI
- SSEi Member
aftermarket, but not low end.
- Pair of SSEI
- SSEi Member
Success. About 3 hours, not too bad. no rusted bolts. Subframe was solid. Tricky to put new bushing in place , up and down with the jacks holding the frame. Almost need 3 hands. tight area to work. stage one of the front suspension rehab complete.
