Code P102 and P0135, car is sputtering &dies.
Ljwilds
Year and Trim: 2004 pontiac bonneville
Post by Ljwilds »
My 04 Pontiac SLE started to loose power and sputtering while driving on the freeway and then stopped. Now if I try to drive it, it will sputter and die like its not getting fuel.
Help, My husband dont know where to start.
J Wikoff
Re: Code P102 and P0135, car is sputtering &dies.
Post by J Wikoff »
My thought is the P0102 is caused by a bad MAF sensor, which is screwing with the airflow mixture which could be causing the pcm to think the bank 1 O2 sensor is bad.
Ljwilds
Post by Ljwilds »
Do you think it could be caused by me spraying carb cleaner in the throttle body? But the car was not running.
Sean
P0102 is absolutely telling you that you have a faulty MAF sensor. Unplug the sensor and it should run better.
Replace the sensor only with OEM, the aftermarkets are junk that only last months.
https://www.amazon.com/dp/B004SJS8YE
Ljwilds
Post by Ljwilds »
Thank you,
We will start there. How long can I drive with the sensor unplugged? Any opinions about a used MAF?
Indefinitely, it's just the car won't be running optimally and you might notice a decease in fuel efficiently or power.
A used OEM MAF would be fine, as long as it's a known good.
