I have removed the stock radio and put in a pioneer. However, I cannot find a circuit where when I turn the key into the accessory mode that it comes on. I am tapping into wires (which I know I should not do as I don’t know what it could affect), and using a relay with power routed from the battery.
If anyone can point me in the right direction, I would be greatly appreciated of it
2005 SLE
rynmcdonald
- Posts like an LG3
- Year and Trim: 2003 Bonneville SSEi.
rynmcdonald
- Posts like an LG3
Re: 2005 SLE
Almost a week and no reply? I know people are busy and all, but was hoping for one.
- harofreak00
Re: 2005 SLE
Not a common request and there are only a handful of active members.
Ignition switch, black connector, pin C, brown wire, Accessory Voltage
- samples08
- Posts like an L36
- Year and Trim: 2002 SSEi
88,000k - Location: Piedmont South Carolina
Re: 2005 SLE
Walmart sells a pin out connector for I think about 20 bucks save you alot of headache Amazon may have one to for cheaper
Member #3848
2002 Black Bonneville SE Sold But Not Forgotten
2002 White Bonneville SSEi Project car
- samples08
- Posts like an L36
Re: 2005 SLE
Scosche GM07B Compatible with 2000-05 GM Ribbon Style Connector/Wire Harness for Aftermarket Stereo Installation with Color Coded Wires https://a.co/d/a1r3JWQ
Member #3848
