Overheating...fans not coming on
Troxartes
- Year and Trim: 1998 Pontiac Bonneville SSEi
Weird bunch of events after an oil change....I've had an overheating problem for about a month, did the oil and figured that would do it. It didn't, but I discovered that the fans weren't turning on and thermostat was bad so I changed that and the coolant temp sensor just in case. Started it, and now the water pump is spraying, and the fans still aren't turning on unless I run the AC. Going to replace the water pump soon, but what could be making the fans not work? Could it be a fuse issue?
- 95naSTA
- Year and Trim: 95 SLE
Re: Overheating...fans not coming on
It could be the fan relay(s).
Troxartes
OMG, thank you for the diagram!
Will check this out and report back....
