How can the Aux input for CD changer be converted to USB?
2000SE
Year and Trim: 2000 se
Post by 2000SE »
It is a 2000 SLE. The factory head unit has the CD/Tape button.
Is there an adapter that can plug into the Aux input that will permit USB input?
J Wikoff
Re: How can the Aux input for CD changer be converted to USB
Post by J Wikoff »
There's usb-c to 3.5mm adapters. Lots of them on Amazon.
2000SE
Post by 2000SE »
J Wikoff wrote:There's usb-c to 3.5mm adapters. Lots of them on Amazon.
A 3.5mm adapter will plug into the AUX CD port? Is there an AUX CD port?
The easiest thing to do is to use a Bluetooth cassette. You can't really add aux to this radio without cracking it open and doing some soldering.
J Wikoff
Post by J Wikoff »
I guess I'm not familiar with the newer radios. I thought aux port meant a 3.5mm plug.
I'm going to recommend a receiver that has an fm modulator. There are many out there with USB inputs and Bluetooth. Then just tune the radio the the right frequency.
