1996 SE Auto unlock
Evan0801
Year and Trim: White 1994 Pontiac Bonneville SE, 3800 Series 1.
1996 SE Auto unlock
Post by Evan0801 »
The doors will lock when put into gear and they don't unlock until the key is off. I was thinking the doors should unlock when the shifter returns to park? Did this update not come until later? Anyway to change when the doors unlock?
1994 Bonneville SE - Series one. L27
1998 Bonneville SE - Series Two. L36
2001 Bonneville SSEI - Series Two. L67
Re: 1996 SE Auto unlock
This was an option to change on the 2000+ models, but not on your 96. I pulled this from the factory service manual. Looks like Pontiac has to be turned to OFF.
Automatic Door Lock Programming
The automatic door lock function provides for the following four selectable settings:
No automatic door lock or unlock.
Automatic all doors lock when the gear selector moves out of PARK (P). No automatic door unlock.
Automatic all doors lock when the gear selector moves out of PARK (P). Automatic driver door unlock when the gear selector moves into PARK (P). (Key is turned to OFF, Pontiac).
Automatic all doors lock when the gear selector moves out of PARK (P). Automatic all door unlock when the gear selector moves into PARK (P). (Key is turned to OFF, Pontiac).
Programming may be accomplished by using the scan tool and accessing RFA special feature menu set option/FOB option #2, through the following method:
Automatic Door Lock System Description
Automatic Door Locks
The automatic door lock function is controlled by the remote function actuator (RFA) module on the vehicles equipped with the keyless entry. The RFA module receives a signal from the park/neutral position switch signaling whether or not the gear selector is in PARK. The RFA module provides a signal to the MALL to lock the doors under the following conditions:
The left front door is closed.
The vehicle is in RUN.
The gear selector is shifted out of PARK.
If programmed to do so, the RFA module also unlocks the doors when the gear selector is put back in to PARK.
Ensure the following conditions:
The ignition is in the ON position
The vehicle is in PARK
All of the vehicle's doors are closed.
Once these conditions are met, hold the door lock switch and press the lock button on the customer's transmitter. After the initial activation of the transmitter LOCK button, each additional activation will increment the Automatic Door Lock (ADL) mode by one, starting from the current ADL mode. If cycled beyond ADL mode 3, the RFA module will enter mode 0. During this customization procedure, the automatic door lock and unlock shall operate as defined, providing the customer with feedback of the current ADL mode. When the door lock switch is released, the RFA module shall remain in the most recent ADL mode. Note that since mode 0 has no ADL functions, no feedback is provided.
Note also that if ignition voltage is lost or any door is opened while in the customization procedure the ADL procedure will be terminated and the RFA module will remain in the most recent mode.
Delayed Locking
Important
The delayed locking feature must be initially enabled with the scan tool in order to gain access to this feature.
The RFA module software for the delayed locking feature is turned off on all new vehicles and service replacement parts.
Use the following procedure in order to perform the initial activation of delayed locking:
Connect a scan tool.
Select the vehicle being programmed.
Select Body.
Select RFA.
Select RFA Test.
Select Set Options
Select Options 0
Follow the screen prompts and instructions.
During step 8 use the EXIT key in order to change from one function screen to another. Do not use the YES or NO keys. If the YES or NO keys are pressed other features may be disabled.
Scroll through the screens until Delayed Locking is displayed, then select YES.
Exit the system.
Disconnect the scan tool.
Activate the delayed locking feature by using the following procedures:
Activate the lock switch with the driver's door open. A chime will sound in order to let the driver know that he/she is in delayed locking mode.
After all doors have been closed for 5 seconds they will lock automatically.
Opening any door before the 5 seconds have elapsed will suspend the timer and cause it to reset once all the doors are closed again. This feature may be programmed on or off for each transmitter.
Deactivating the Delayed Locking Feature (if currently enabled)
Use the following procedure in order to deactivate the Delayed Locking feature:
Hold the lock switch on.
Press the transmitter UNLOCK button. All doors will unlock, but Delayed Locking remains enabled.
Press the transmitter UNLOCK button again. All the doors will lock, and Delayed Locking will be disabled.
Activating the Delayed Locking Feature (if currently disabled)
Hold the lock switch on in order to activate the delayed locking feature.
Evan0801
Post by Evan0801 »
Thanks for the information. I've really dug into the 96-99 auto unlocking feature and have found some interesting information i think would be helpful for anyone in the future. 96,97,98-99 have different defaults. Changing these settings can be found in the owners manual of correct year.
1996:
1 no automatic door lock.
2 All doors automatically lock when shifted out of PARK. No automatic door unlock.
3 All doors automatically lock when shifted out of PARK. All doors unlock when in park with key OFF. DEFAULT SETTING
1997:
0 no automatic door lock.
1 All doors automatically lock when shifted out of PARK. No automatic door unlock.
2 All doors automatically lock when shifted out of PARK. Only the driver's door automatically unlocks when shifted into PARK.
3 All doors automatically lock when shifted out of PARK. All doors automatically unlock when shifted into PARK. DEFAULT SETTING
1998/1999
0 No automatic door lock.
2. All doors automatically lock when shifted out of PARK. Only the drivers door automatically unlocks when shifted into PARK with key off.
3. All doors automatically lock when shifted out of PARK. All doors automatically unlock when shifted into PARK and the key off. DEFAULT SETTING
