Argh !!! Stuck wheel bearing!! Help
mark a. chew
- SSE Member
- Year and Trim: 2004 Bonneville GXP
2008 Grand Prix GXP - Location: Indianapolis, Indiana
Trying to replace the hub bearing on my left front corner. Having a hell of a time breaking lose the hub. All the bolts are out. Any suggestions??
- 95naSTA
- Year and Trim: 95 SLE
Re: Argh !!! Stuck wheel bearing!! Help
I'm not sure if there's room but you could thread in one of the bolts in through the back so it's a few mm from seated, put a socket and extension on it and bump it with a mini sledge.
96 SSEi
- Posts like a Northstar
get a thin flat screwdriver anound hub assembly working all the way around evenly
lightly pry about 1 mm / 1 thousands of inch at a time in one spot. then work your way around the hub - nice and slowly - keep it even
- 95naSTA
^^ Be careful with that mating surface since it's aluminum and soft.
- nos4blood70
- Year and Trim: 2003 SLE
Let that thing eat some PB Blaster for an hour or two, that has never failed me yet.
- Archon
I used a slide hammer to get them off. You can probably rent one.
mark a. chew
- SSE Member
Well I have been soaking it with PB Blaster for two days. And I spray where the axle nut was up through the splines and also where it mated with the knuckle. This car was bought in Michigan so I imagine the winters of salt isn't doing me any favors. This actually is not on my Bonneville GXP, it's on my 'O8 Grand Prix GXP. The Bonneville was definitely easier, I was drinking beer in under an hour. Lol. Thanks Guys for the help!!! I will try everything suggested. Will keep you posted.
mark a. chew
- SSE Member
So how does the speed sensor connector and wire go through the hub. With the drive axle attached.
- 95naSTA
Don't you just put the connector through, then seat the hub on the axle splines after?
mark a. chew
- SSE Member
That's kinda what I thought, but figured I would ask. There just doesn't seem like there is enough room with the axle shaft attached. Can I move the axle and cv joint around to get the connector through there??
96 SSEi
yes, try moving the wheel and see if you can wiggle it through - last ditch attempt - you could cut the connector off and reconnect once you got it through.
- 95naSTA
The axle nut should be undone at this point, giving you enough room. The axle can also compress toward the trans a bit too.
