Radiator fans only come on with A/C
Kevdadi
Year and Trim: 2003 Bonneville SE
Post by Kevdadi »
Hello-
I have a 2003 3.8l Bonneville that stays cool because I kive in 90+ degree Florida! If I turn off the air conditioning the fans do not run... no overheating, but temp goes a tick over 200 and holds steady.
I looked around a little bit for some ideas, but do not know how to diagnose.
No overheat condition, but rad fans wont come on without the air conditioning...
Thanks!
AJT2004
Re: Radiator fans only come on with A/C
Post by AJT2004 »
From what you describe there is no problem and the cooling system is functioning normally.
luke_dubs
Year and Trim: 2013 Regal GS
Post by luke_dubs »
Sounds normal to me as well. I thought I had an issue as well (same diagnosis as you) but nope. Everything is okay.
'13 Buick Regal GS 122k miles, 270 hp, 295 lb/ft, ZZP intake.
rustyroger
Year and Trim: 1998 Buick Park Avenue
Post by rustyroger »
Let the car idle in still air and see if the fans come on. They shouldn't until the coolant temperature reaches around 220 degrees, and should shut off when it gets below maybe 180.
If you keep moving the fan will almost never come on, the flow of air through the radiator is enough to keep things cool.
Roger.
RJolly87
Post by RJolly87 »
If the gauge holds steady a tick above 200 while just sitting there idling, either the fans are coming on, or there is enough air moving through the radiator (a breeze) to keep temps in check.
As mentioned, fans don't come on low until 215 (approx) and hit high if it pushes beyond 225, or if they are required for air conditioning. It's very rare that the fans will ever run at high speed under normal conditions, aside from A/C.
If the fans are on low, it's possible they are running but you simply can't hear them. They should shut off once it cools down around 210 or so.
