Reached an impasse. This is my wife's GXP and the one I pulled the engine to R&R the oil manifold plate. No codes but it has an Idle surge. I performed a injector cutout test with my Tech II and all injectors cut out with a noticeable reduction in RPM. Viewed the misfire graph and when it surges cly 4 has the accumulated current counters, reaching the max of 64. When there is no surge the accumulated current counters reads zero.
I've checked for vacuum leaks, swapped coils and plugs, clean MAF sensor and throttle body with MAF cleaner. New coil packs on 2,4,6,8 and all new plugs.
Any ideas????
Kevin
Idle surge
Kevin Amstutz1
- Year and Trim: 05 red GXP, 05 white GXP, 03 SSEI, 02 SSEI
Idle surge
05 GXP Red, 05 GXP White, 03 SSEI, 02 SSEI, Sold 98 SSEI, 98 SE, 98 SLE, 98 SSE
- CMNTMXR57
Re: Idle surge
Two thoughts;
1) TPS readings. What's going on here?
2) Cat Converter issues? But that doesn't explain only one cylinder loading up.
2011 Camaro SS
Kevin Amstutz1
Re: Idle surge
What should the TPS readings be? I already shipped my manuals for my next move.
- CMNTMXR57
Re: Idle surge
I don't have the stat memorized, but TPS is measured from 0 - 5 volts. 0 volts = closed. 5 volts = WOT.
So for idling, it should be somewhere less than or around 1 volt and be steady.
There are three circuits on a TPS. One supply voltage, one a ground, and one the actual voltage of the sensor.
Supply should be ~5v
Ground should be grounding
The actual is the actual blade/throttle position.
If you have a bad ground, and or you see that actual bouncing around... That might steer you somewhere.
2011 Camaro SS
Kevin Amstutz1
Re: Idle surge
TP - 0%
TP - .55 at idle (Surging)
IAC goes from 50-108 counts
MAF goes from 0-12 g/s
Engine load 31-57%
MAP 41-56kpa
MAP 1.06 - 2.69 volts
No codes or check engine light. Ground connections on front lower trans connected, IIRC 3e and clean.
Engine load 31-57%
MAP 41-56kpa
Kevin Amstutz1
Re: Idle surge
I've checked all of my known vacuum connections for leaks and still have an intermittent surge. Most prevalent when initialing coming to a stop and then goes away for a moment and then comes back. Again no check engine light.
Sorry it's been a while but we moved to FL and been busy at work.
Kevin
Kevin
Kevin Amstutz1
Re: Idle surge
After many checks and head scratching, I fixed the problem. It does make a difference which of the two Crank sensors goes in their mounting position. I swapped the sensors and no more surge.
Kevin
Kevin
