Hello, I am a new member to this forum in order to help out my 17 year old son as much as possible. My son purchased a 2000 Bonneville SE, that appears that to him appeared to be in very good condition, however we encountered some bumps along the road getting this to pass a Virginia State Safety inspection. I have registered here in hopes of assistance that you may be able to provide. I will list below what symptoms we have had, what we have been able to fix and what we still have outstanding. Again any assistance would be greatly appreciated, and thank you in advance.
- Random misfire code: Ignition control module replaced (so far so good)
- ABS and Brake light on at all times: EBCM Repaired, and currently no lights (keeping fingers crossed)
- Low tire pressure light on at all times: All tires replaced (so far so good as well)
- Sun roof falling in and rain getting in: My plan is replace the glass and seal, and then fix the damaged headliner.
- Only drivers side window works: I have read that it is a possibly bad splice under the carpet on the drivers side front, I will inspect that by this weekend.
V/r
Mac Arnold
New member from Hampton Roads Virginia
Mac Arnold
- LE Member
- Year and Trim: 2000 Pontiac Bonneville SE
