ambiant temperature sensor
2005 pontiac
- SE Member
- Year and Trim: 2005 Pontiac Bonneville 3.8 SE
The owner's manual for my 2005 pontiac bonneville states that there is also an EXT (exterior) temperature sensor located behind the front grill. This sensor reads the outside air temperature and helps to maintain the temperature inside the vehicle. Any cover on the front of the vehicle could cause a false reading in the temperature. I've looked all over and I can't find it. Can someone send a diagram where it is? Thanks!
ddalder
Re: ambiant temperature sensor
I'm sure the mods will move your original thread, no need to start a second. I did post again in your original thread with the answer
