Stalling under acceleration
Bonneville'n
Post by Bonneville'n »
So i had this problem last year and it went away when it got cold, now its back with warmer weather. Mostly happens when accelerating up a hill or passing someone. Any ideas??? Thanks for any help.
240k, Cleared Corners, Silverstars, Yellow 893 fogs, LED Marker,
Reverse & interior bulbs, L32, Triple Edge
transmission, Intense FWI, N*, GXP Brake & Swaybar Swap, Pacesetters
Re: Stalling under acceleration
Does it happen at any particular speed? Typically in a higher gear or specific RPM? Sounds like either spark or fuel issue.
Bonneville'n
nos4blood70 wrote:Does it happen at any particular speed? Typically in a higher gear or specific RPM? Sounds like either spark or fuel issue.
2nd gear down shifts maybe, about 40-50 mph. When it happens i loose power, no throttle and will eventually die, i just put it in neutral and turn the key off and it starts back up.
96 SSEi
Post by 96 SSEi »
history of maintenance would help - plugs, wires, and the such
is the ses light triggered when this happens and any codes?
Bonneville'n
96 SSEi wrote:history of maintenance would help - plugs, wires, and the such
Plugs and wire done 3 years ago...only code im getting is po442
maxi426
Year and Trim: 2003 SSEi
1999 Park Ave. Ultra L67
Post by maxi426 »
Sounds like time to drive it with a fuel pressure gauge attached so you can watch it.
96 SSEi
Post by 96 SSEi »
that po442 is a hard code - did you have any pending codes along with it?
Bonneville'n
Fuel pump was done about a year ago. No other codes pending.
MikeKerr
Post by MikeKerr »
Check for corrosion where the coils plug in. Only takes a few moments, very easy to do. I had one of the three sets of coils have corrosion on its contacts causing the same issue. No idea why the center coil back had contact corrosion. Took only a few minutes to pull the coil, sand off the corrosion, and put back together.
maxi426
Post by maxi426 »
Bonneville'n wrote:Fuel pump was done about a year ago. No other codes pending.
I wouldn't let that stop me from checking fuel pressure under load. Symptoms would have me thinking fuel supply, or restricted exhaust.
