So far I dropped the cradle and motor and removed the heads
Yes, that is coolant on top of the pistons.
The heads went to be crack tested and came back good
Now I'll need to clean up the block surface and find a way to get the guide dowels out - I can't even turn them they are hella seized.
Luckily I was able to borrow the repair kit (guide plate, drill bits, tap, etc.) from a local dealer so I don't have to buy that.
Hopefully I'll post more pics as I go along
