Power steering fluid maintenance
inition
Year and Trim: 1999 Oldmobile 88 LS
Post by inition »
When changing plugs, I looked down and found the power steering reservoir for the first time. I never checked it once yet. The fluid has 190k miles. Is there a way to drain the system and replace the fluid?
J Wikoff
Re: Power steering fluid maintenance
Post by J Wikoff »
Use a baster or something to suck all the fluid out of the reservoir and fill it with new fluid, start the car, cycle the steering wheel lock to lock a few times, repeat a couple times.
